- Thank you received: 449
My Grizzly G0619 mill
- my1987toyota
tommylight wrote: Building the machines!
what if its making the parts to build more machines ?
- Thank you received: 7491
That's why i have 3D printers now, printing parts for more 3D printers !my1987toyota wrote:
SEND HELP !!!!
- my1987toyota
See tommylight first step is admitting it. LOL
- my1987toyota
in the process of doing that I ended up writing a simple MPG hal. for a 5 axis with Feed and Spindle override.
I will actually be using a 4 axis on the mill. If anyone is interested check out this subject here on the forum
[url] forum.linuxcnc.org/47-hal-examples/42913-simple-mpg-hal-s [/url]
- Thank you received: 4153
Your next challenge is to use some of the MUX components to reduce the pin count.
eg you can do scale select with 2 pins and 5 axis select with 3 pins
To do 5 axis plus 2 overrides you will need 4 pins which would allow 16 seperate selections
to do this you have to think in binary and from memory you need to convert from a float to long integer using the correct hal component..
- my1987toyota
Admittedly yes it's a bit of a pin hog . Simple can mean many things this would be the easiest one I feel a nooby ( like myself ) could wrap their head around.rodw post=213064 userid=20660Great work but it looks like you are consuming a lot of pins. This could pose a problem down the track if you are really a machine building addict who by definition wants to consume all the available pins!
Also I am not fully up to speed yet on using mux4 or mux16 to bring the pin count down . I did fiddle around with mux16 a little to bring the pin count down but I didn't feel comfortable baking that into the code at this point . In my opinion their is a lack of easy hal. examples and integration of MPG panels or pendants. Even pro athletes have to start with baby steps. Linuxcnc is no different. That said I do intend to do more complicated but lower pin count MPG's down the road.
