My Grizzly G0619 mill
4 years 3 weeks ago #253857 by my1987toyota
Replied by my1987toyota on topic My Grizzly G0619 mill
And here is part 2.
[url]
[/url]
3 years 9 months ago - 3 years 9 months ago #261979 by my1987toyota
Boy time flies. It's hard to believe it's 2023 already. I had taken about a month to upgrade my
Anodizing line to make it more user friendly and more automatic. I can now get to work (5:30am) and
the tanks are either already at temp. or will be so when it's needed. On the G0619 I built most of
the external wiring . So I figured the next step was to cut out the I.O. plates . Unfortunately I ran into
an issue with my Autodesk Fusion 360 software. I sent a couple of DXF files to a company that does
water jet / laser cutting only to have the finished job be twice the size I had specd ( not their fault ).
Frustrating to say the least , more so at my self for not catching it and fixing it before I had sent it out.
Oh well it's always something.
Last edit: 3 years 9 months ago by my1987toyota.
3 years 9 months ago #261980 by rodw
Replied by rodw on topic My Grizzly G0619 mill
That sucks. I always send a pdf drawing of the part with any DXFs we send out.
It might have let you blame them and not wear the recut!
Also the F360 DXF workflow I use is to:
1. Create a flat pattern and flatten it If sheetmetal
2. Add a new sketch on the flat pattern  or surface of the part if not sheetmetal
3. Now in the tree, right click the sketch and save as DXF
4. Create a sketch showing outer dimensions and dimensions to any fold lines
5. send the pdf and dxf to supplier..
The following user(s) said Thank You: my1987toyota
3 years 9 months ago #262049 by my1987toyota
  I figured I would post some pics. for people to get a laugh at. The one I set a DB37 connector on just to
give a sense of scale compared to the cutout it was intended for . The other I put an Mpg Pendant on
to again show the over-sized scale.
3 years 9 months ago #262070 by rodw
Ouch! and you paid money for that?
And it does not even seem to be a metric thing!
Send a dimensioned drawing with it next time! Or build a plasma table!
  • Moderator
  • Moderator
3 years 9 months ago #262074 by tommylight
Replied by tommylight on topic My Grizzly G0619 mill
Hmmm, did you pay for the small ones or large ones? :)
Time to create page: 1.088 seconds
