My Grizzly G0619 mill
3 years 6 months ago #270323 by my1987toyota
Replied by my1987toyota on topic My Grizzly G0619 mill
admittedly I had to look that up. LOL  Are you using a raspberry Pi or converting it to Linuxcnc?
  • Moderator
  • Moderator
3 years 6 months ago #270345 by tommylight
Replied by tommylight on topic My Grizzly G0619 mill
No, not LinuxCNC yes, but following development Scott and the gang are working on, so ... I would love to move to it though.
As for RPI, i have 2 collecting dust, i use laptops with Linux Mint and Klipper to run my printers.
RPI would crap out whenever taking a screenshot at 1920x1080 and sending it via Telegram Bot! Stopped the printing dead! I can not allow that. :)
I also do not like Klipper, way to much stuffed in it and to many workarounds and to many dependencies and to many ... everything.
But it does work, had 2 of my printers on for over 2 months, one errored out on it's own, while idle.
The following user(s) said Thank You: my1987toyota
3 years 6 months ago #270347 by rodw
Replied by rodw on topic My Grizzly G0619 mill
I had to go back to the beginning of the thread and refresh my memory because I have the same mill (still a manual). Really looking good.
I really don't like the GX connectors, so much soldering (although I must say my new Hakko iron is an improvement).
I have been using automotive QC connectors at the motor end. Crimp on and nice and light so they can hang in the air. First time around, I  mounted GX panel mount connectors at the motors to support the weight of the connector. It's just a shame they are not compatible with the standard colour coded crimp on spade connectors.
  • Moderator
  • Moderator
3 years 6 months ago #270351 by tommylight
Get an TS-80P, that will change for sure.
I did, it did. :)
Just knowing it is ready in 20 seconds, running from a power bank or a Bosch battery, simply removed any latent lazy-ness.
3 years 6 months ago #270368 by rodw
​​​​​​Yeh, I looked at them. Went with Hakko as I could get it faster.
My ears plucked up when you said Bosch battery. Sometimes I need to solder on a vehicle so a corded one is a pain.
​​​​​​And I have a lot of Bosch tools. This one looks interesting!
www.jmmsolutions.com.au/products/bosch-c...ttery-solder-station
The following user(s) said Thank You: tommylight, my1987toyota
3 years 6 months ago #270405 by my1987toyota
I am not the biggest fan of the GX connectors because you have to solder them and a standard soldering iron just heats the
crap out of the connector before the solder flows . That said I have a work around called Hako FR301 de-soldering iron.
it's the only thing I have that has enough thermal mass to heat the solder joint before the rest heat soaks.
I also up-rated my connectors to GX20-4 for the stepper motors.
Time to create page: 0.255 seconds
