Homemade, cheap, plasma CNC
5 years 2 months ago - 5 years 2 months ago #217183 by phillc54
I don't understand why then the configurator was built into a python 2 application.
Because python2 was the official development environment at the time and PnCconf should have been ported to python3/Glade3 during the conversion process like all the other GUI applications were.
It seems also the QTdesigner is a Python 2 application.
AFAIK designer is written in C++ or similar.
I'd like to see a clean break once the python issues are fixed and ensure release of V2.9 occurs on a ISO-less Debian Bullseye environment.
I don't understand what you mean by this. Packages are available.
Yes the package  building was pretty straightforward and unearthed a few more dependencies.
I don't do package builds often but yeah, they normally go quite easily.
Just the docs forgot to tell you where to look for them.
I imagine PR's would be welcomed for the document updates.
Last edit: 5 years 2 months ago by phillc54. Reason: Three attempts with this STUPID editor...
5 years 2 months ago #217187 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
There are no packages for Bullseye and the Buster ones don't work due to different dependencies.
I did try changing the repos in Synaptic in case there was something there but all I got was the docs.
I'll try your script re QT. I did not install the designer stuff. I thought I saw some Python 2 dependencies loaded by it.
5 years 2 months ago - 5 years 2 months ago #217202 by phillc54
The script in master is all python3.
I fixed my last mistake today....
5 years 2 months ago - 5 years 2 months ago #217458 by snowgoer540
At least it can be used without massive latency like the builtin causes on my Brix J1900.
I’m curious… did you have to disconnect the card inside the computer or was disabling the WiFi enough?
Last edit: 5 years 2 months ago by snowgoer540. Reason: Spelling
5 years 2 months ago #217483 by rodw
I’m curious… did you have to disconnect the card inside the computer or was disabling the Sufi enough?
Its a long time ago but I think not installing the driver was sufficient but I removed the supplied Intel Bluetooth/wifi card to be sure.
4 years 11 months ago #225640 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Update - 8/11/21
New pc (2007 iMac) to install QTplasmac.
Still working through some coding issues to get the probe/float to work, and then we can start cutting again.
Time to create page: 0.098 seconds
