Homemade, cheap, plasma CNC
- Thank you received: 4149
10 Nov 2021 11:43 #225961
Replied by rodw on topic Homemade, cheap, plasma CNC
Ooops not dd. I used Gparted as it has a GUI
- Thank you received: 7478
10 Nov 2021 12:07 #225967
Replied by tommylight on topic Homemade, cheap, plasma CNC
Noooooooooooo
Just zip the folder and copy with a normal USB.
Zip or TAR.GZ will preserve symlinks.
- RNJFAB
- Thank you received: 59
13 Nov 2021 10:18 #226303
by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Tonights challenge - get a button to turn on/ turn off the laser to sight in the job & load my toolsets from SheetCam into QTPlasmaC.
I'll let you know it goes.
- RNJFAB
21 Nov 2021 03:06 #227139
by RNJFAB
Tried every combination that I could from reading a lot of posts, but I'm still unable to turn on an output from a button on the Plasmac GUI.
I'll try and post the combinations I have tried.
- phillc54
- Thank you received: 2100
21 Nov 2021 03:11 #227140
by phillc54
Replied by phillc54 on topic Homemade, cheap, plasma CNC
Posting the code is good, or even your complete ini file.
Is it PlasmaC or QtPlasmaC that you are using.
- RNJFAB
21 Nov 2021 03:29 #227141
by RNJFAB
Hey Phillc54,
Upgraded to QtPlasmaC.
- phillc54
21 Nov 2021 03:31 #227142
by phillc54
Cool, your last post mentioned PlasmaC and that does the buttons a little bit differently than QtPlasmaC, we probably should have called it something that would be a bit less confusing. Anyhow it is what it is now ...
21 Nov 2021 03:34 - 21 Nov 2021 03:35 #227143
try something like
net laser:switch qtplasmac.laser_on => my-mesa-output-pin
Last edit: 21 Nov 2021 03:35 by rodw.
- RNJFAB
21 Nov 2021 04:18 #227145
by RNJFAB
Still no dice.
Still no dice.
21 Nov 2021 04:31 #227148
not what I said. you have created a signal but its not connected to anything . Try
Still no dice.
net plasmac:laser-switch qtplasmac.laser_on => hm2_7i96.0.ssr.00.out-01Please Log in or Create an account to join the conversation.
Time to create page: 0.528 seconds
