Homemade, cheap, plasma CNC
11 Aug 2021 03:12 #217483 by rodw
Replied by rodw on topic Homemade, cheap, plasma CNC
At least it can be used without massive latency like the builtin causes on my Brix J1900.
I’m curious… did you have to disconnect the card inside the computer or was disabling the Sufi enough?
Its a long time ago but I think not installing the driver was sufficient but I removed the supplied Intel Bluetooth/wifi card to be sure.
08 Nov 2021 02:45 #225640 by RNJFAB
Replied by RNJFAB on topic Homemade, cheap, plasma CNC
Update - 8/11/21
New pc (2007 iMac) to install QTplasmac.
Still working through some coding issues to get the probe/float to work, and then we can start cutting again.
  • Moderator
  • Moderator
08 Nov 2021 03:53 #225649 by tommylight
Replied by tommylight on topic Homemade, cheap, plasma CNC
To test the float switch all you have to do is move the torch up by hand and watch the screen, the "float" LED should turn on even when machine is disabled.
I think i already mentioned this, but probably the float switch pin is not in HAL where it should be.
08 Nov 2021 04:13 #225654 by RNJFAB
Thanks Tommy,
the 'float' led doesn't light up.
I have checked the Hal show and can see it working so know the mechanical side of things is right.
I setup using PnCConf wizard.
Can you share a copy of your HAL file and what it should look like, I have tried to use what was working in PlasmaC Hal file, however haven't got this right yet.
Cheers
  • Moderator
  • Moderator
08 Nov 2021 04:33 #225658 by tommylight
Yes i can but it will confuse you even more as all my Plasma configs are hand edited.
I will upload them when i get to the machines.
08 Nov 2021 05:25 #225664 by phillc54
Replied by phillc54 on topic Homemade, cheap, plasma CNC
In your Hal file you should a a line something along the lines of:
net plasmac.float <= your-hal-pin-that-lights-up
The following user(s) said Thank You: RNJFAB
08 Nov 2021 05:42 #225666 by RNJFAB
File Name: PLASMAhal.txt
File Size:14 KB
My Hal file
Key lines
85 # --- PROBE-IN ---
86 net float-switch    <=  hm2_7i96.0.gpio.008.in
311 #  ---probe signal---
313 net float-switch     =>  motion.probe-input
334 et plasmac:float-switch-out     db_float.out                =>  plasmac.float-switch
08 Nov 2021 05:49 #225667 by phillc54
313 should be:
net float-switch => db_float.in
08 Nov 2021 05:55 - 08 Nov 2021 06:29 #225668 by RNJFAB
Error - 316: Pin 'db_float.in' was already linked to signal 'plasmac:float-switch'
Line 38 in Hal file
38 net plasmac:float-switch     => db_float.in
I have tried to copy the old PlasmaC file to patch things. Clearly i know not what commands do.
Thanks Guys. I'll try and read up a bit more, I probably missed it in the config (most of the details i edited after setup to match what i had with the setup on PlasmaC anyway).
Last edit: 08 Nov 2021 06:29 by RNJFAB.
08 Nov 2021 16:07 #225725 by phillc54
Then you need:
net plasmac:float-switch <= hm2_7i96.0.gpio.008.in
Time to create page: 0.748 seconds
