I had some time to try out some new work holding, and it does open up ways to go about secondary operations. But what i noticed is working holding factors into these little machines quite a bit. when you start getting into thicker pieces. radial cutting becomes a pain when you want a good finish. one other thing i don't care for with the new clamps is the fact that you have to count on aluminum threads. over time they will fail due to wear and since it is part of the clamp that will become a problem at some point. So i think i will try a new approach with a 3 part clamp that uses the steel T nuts for the clamping force. once I thought of it i was like stupid simple is a Plus sometimes
one other thing i was working with was the uses of work offsets. and came into the issue of table variation on the Z axis. i wanted to try not skimming the table top but i think if i do it will make things much more simple in the long run.
i actually am waiting for some solid carbide High-feed mills to try too. I think they might work well with this machine they are not cheap but if they work well it is what it is and you just suck it up
