Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
- RNJFAB
- Thank you received: 59
20 Dec 2024 04:13 #317037
by RNJFAB
Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34. was created by RNJFAB
So, after the success of my first plasma CNC, I thought it time to move her on to a new home, and build a new one. Bigger, faster, more powah!!!
Im starting with a MESA 7i96 with 2x THCAD10 for volts and ohmic sensing. Closed loop stepper motors will be Nema 34 running 60v. Reduction gearboxes onto helical gears. The z axis will bolt the hypertherm xp45 machine torch and an air scribe. I’ll use an air actuator to drive the scribe to the required height. Everything is running on aluminium extrusion and linear rails. I have prefer up a water bed that is 1500x3000. Giving me adequate space to load up a full sheet.
I’ll get some pics and links to the parts used as I go along.
lots of new things for me to learn with this build so no doubt I’ll be calling on the brains trust for guidance again and to help me when I get myself stuck.
cheers
cheers
- Thank you received: 7504
20 Dec 2024 12:24 #317051
Replied by tommylight on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Have not seen you on youtube lately, but i fear that is the dreaded "algorithm", glad you are OK and still kicking.
The following user(s) said Thank You: RNJFAB
- RNJFAB
27 Dec 2024 05:55 #317463
by RNJFAB
Replied by RNJFAB on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Yeah, was a bit sick at the start of the year and had 6 months off work, not much happened at this time, just me thinking about this new build.
Very busy otherwise, I work full time, and I cut steel signs, and I run a small mowing business, and I work for my brother in his fabrication workshop, AND I'm still building my own house.
New build is coming along nicely.
Machine is built, most mechanical fitout complete, and started on the wiring tonight.
Pics to follow
Pics to follow
- RNJFAB
01 Jan 2025 15:41 - 01 Jan 2025 15:44 #317803
by RNJFAB
Last edit: 01 Jan 2025 15:44 by RNJFAB.
01 Jan 2025 16:25 #317808
In PncConf set the number of PWM to 0
- Thank you received: 5336
01 Jan 2025 18:20 #317832
Replied by PCW on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Looks like you used a 7I96S configuration file for a 7I96
- RNJFAB
01 Jan 2025 18:21 #317833
by RNJFAB
01 Jan 2025 19:53 #317845
Networking not set???
What does
ip a
return?
What does
ip a
return?
- RNJFAB
01 Jan 2025 20:02 - 01 Jan 2025 23:57 #317846
by RNJFAB
Last edit: 01 Jan 2025 23:57 by RNJFAB.
- RNJFAB
01 Jan 2025 23:58 - 02 Jan 2025 01:57 #317859
by RNJFAB
OK.
Wasn't sure about a real time kernal, so check and have "6.1.0-28-rt-amd64".
Have uninstalled all traces of LinuxCNC, and now using the synaptic package manager, have loaded the latest linuxcnc versions.
Start up pnfcof with the mesa 7i96, everything worked.
Still having the same issue. estop is red, cant be unclicked.
Cant select power. left hand side of the screen is blank/glitchy.
Any ideas??
Any ideas??
Last edit: 02 Jan 2025 01:57 by RNJFAB.
Time to create page: 0.617 seconds
