Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
04 Feb 2025 06:36 - 04 Feb 2025 08:15 #320577 by RNJFAB
Halshow has the reading fluctuating from about -3650 -> +3650 with no plasma source having power.
in linuxcnc, the arc reading sits at -29
Jumping the B input?
Confirmed - mesa i/o pin 10 is lighting up when I should get an arc-ok input from the plasma, but linuxcnc isn't showing this.
Current codes
File Name: T18_2025-02-04.ini
File Size:5 KB
File Name: custom_2025-02-04.hal
File Size:2 KB
File Name: T18_2025-02-04.hal
File Size:11 KB
Last edit: 04 Feb 2025 08:15 by RNJFAB.
04 Feb 2025 10:10 #320589 by tommylight
Repeating myself here, interference, lots of it, so check the wiring and especially the grounding, ground loops will cause havoc.
04 Feb 2025 19:22 #320640 by rodw
you have a 0 volt frequency of 3637 in you system so 3650 is expected. The swings are not
There is something not right in hal, like you have a double ended encoder or something.
The following user(s) said Thank You: RNJFAB
04 Feb 2025 19:55 #320645 by PCW
+- velocity values are not possible in counter mode unless you have noise on the "B" input
Try jumpering the "B" input for single ended mode
(and make sure nothing is connected to either "B" input at TB2)
05 Feb 2025 10:16 - 05 Feb 2025 11:10 #320719 by RNJFAB
Thanks PCW.
Yes, I had the Ohmic sensing into the B encoder input on TB2.
Once this was unpluged, Encoder velocity stayed at 0. or flucuated to -3750.
Grounded everything i could and moved plasma source 30cm further away.
And hey presto.
Last edit: 05 Feb 2025 11:10 by RNJFAB.
05 Feb 2025 16:35 #320766 by PCW
That's OK with 7i96dpl.bit firmware (that has three separate encoder 'A' pins)
14 Feb 2025 08:59 #321522 by RNJFAB
Thanks PCW.
I'll try an reconnect the ohmic to a different encoder A pin.
Also need to work on the air scribe next.
25 Feb 2025 10:54 #322576 by RNJFAB
Its been a very busy few days. slowly getting tools dialed in for the new machine. Still a long way to go with ohmic sensing and the air scribe, but I'm happy with how everything is moving. the factory hypertherm cut charts are about 1000mm/min off what is actually working.
06 Apr 2025 05:57 - 06 Apr 2025 05:58 #325797 by RNJFAB
so working away and everything is going great, until. went to cut some plate today for the air scribe, turn everything on and then, she no connect. Worked fine a few days ago.
This is the error and i can't find a fix. Help
$ linuxcnc
LINUXCNC - 2.9.3-125-g62642dde63
Machine configuration directory is '/home/cnc/linuxcnc/configs/T19'
Machine configuration file is 'T19.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./T19.hal
identityKinematicsSetup: coordinates:XYYZ
   Joint 0 ==> Axis X
   Joint 1 ==> Axis Y
   Joint 2 ==> Axis Y
   Joint 3 ==> Axis Z
identityKinematicsSetup: Recommend: kinstype=both
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 10.10.10.10: Connection refused
hm2_eth: rtapi_app_main: Connection refused (-111)
./T19.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./T19.hal:9: /usr/bin/rtapi_app exited without becoming ready
./T19.hal:9: insmod for hm2_eth failed, returned -1
Running HAL shutdown script
hm2: unloading
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/cnc/linuxcnc_debug.txt
and
    /home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Last edit: 06 Apr 2025 05:58 by RNJFAB.
06 Apr 2025 06:13 - 06 Apr 2025 06:14 #325798 by tommylight
I would guess you changed the IP on the PC ....
That error is almost always due to PC having the IP set at 10.10.10.10 (or 192.168.1.121), set it to anything else for the last 2 (or 3) digits:
10.10.10.11 is fine
192.168.1.100 is fine
etc.
Edit:
check with
ip a
Last edit: 06 Apr 2025 06:14 by tommylight. Reason: more info
