Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
- RNJFAB
- Thank you received: 59
02 Jan 2025 05:38 - 10 Jan 2025 18:31 #317867
by RNJFAB
Replied by RNJFAB on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
So after a few battles, i finally have the mesa board talking to LinuxCNC. I have movement. I have proximity sensors all connected and working. I have coded HAL to get the right distance traveled.
Still to go - laser pointer, z axis, air scribe, water table & tank, paint, clean out shed, concrete for shed floor to hold it.
I still have a glitch in the screen that shows what is being cut, and i get no preview of what i load,
Last edit: 10 Jan 2025 18:31 by RNJFAB.
- RNJFAB
01 Feb 2025 14:59 #320350
by RNJFAB
Stuck with joint errors
thinking the 12v field power isnt enough......
- Thank you received: 4154
01 Feb 2025 16:02 #320354
Replied by rodw on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
James, order one of these to be safe. There isn't any need to go with 12 volt on a plasma cutter.
au.element14.com/mean-well/mdr-60-24/pow...gKi9I4hoCco4QAvD_BwE
Also if it really is hitting a limit switch, use a HOME_OFFSET in your ini file to move the sensor off the limit switch when homing.
The following user(s) said Thank You: RNJFAB
- Thank you received: 5336
01 Feb 2025 16:13 #320356
Replied by PCW on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
Might be noise coupled into the limit switch wiring
Is there any debouncing on the limit switch signals?
What hardware do you have?
- Thank you received: 7504
01 Feb 2025 17:00 #320368
Replied by tommylight on topic Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
If the torch is firing on that video, for sure interference.Might be noise coupled into the limit switch wiring
- RNJFAB
01 Feb 2025 22:55 #320384
by RNJFAB
Thanks Rod, I had a hdr-60-24 arrive today.
not hitting home
not hitting home
- RNJFAB
01 Feb 2025 22:57 - 02 Feb 2025 01:01 #320385
by RNJFAB
not sure about debouncing on the limit switches.
Mesa 7i96,THCAD10, closed loop nema34. hypertherm xp45 with cpc port.
all fixed with the 24v field power. thanks Rod.
next problem is the thc is not reading. I have checked the THC with 9V battery and it works there, so guessing the problem lies in my INI or HAL files.
# Generated by PNCconf at Sun Feb 2 06:15:46 2025
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
[EMC]
MACHINE = T17
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = qtvcp qtplasmac
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files
INCREMENTS = 10mm 1mm 100mm
DEFAULT_LINEAR_VELOCITY = 83.333333
MAX_LINEAR_VELOCITY = 183.333333
MIN_LINEAR_VELOCITY = 1.666667
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
GEOMETRY = xyz
CYCLE_TIME = 100
[FILTER]
PROGRAM_EXTENSION = .ngc,.nc,.tap GCode File (*.ngc, *.nc, *.tap)
ngc = qtplasmac_gcode
nc = qtplasmac_gcode
tap = qtplasmac_gcode
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G49 G80 G90 G92.1 G94 G97 M52P1
SUBROUTINE_PATH = ./:../../nc_files
USER_M_PATH = ./:../../nc_files
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
CARD0=hm2_7i96.0
[HAL]
HALUI = halui
HALFILE = T17.hal
HALFILE = qtplasmac_comp.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ
[TRAJ]
SPINDLES = 3
COORDINATES = XYYZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 18.33
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
# MAX_VEL & MAX_ACC need to be twice the corresponding joint value
MAX_VELOCITY = 366.6666666666667
MAX_ACCELERATION = 4000.0
OFFSET_AV_RATIO = 0.5
MIN_LIMIT = -5.0
MAX_LIMIT = 1300.0
[JOINT_0]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 183.33333333333334
MAX_ACCELERATION = 2000.0
STEPGEN_MAXVEL = 229.17
STEPGEN_MAXACCEL = 2500.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 52.0833
MIN_LIMIT = -5.0
MAX_LIMIT = 1300.0
HOME_OFFSET = -10.000000
HOME_SEARCH_VEL = -50.000000
HOME_LATCH_VEL = -25.000000
HOME_FINAL_VEL = 16.666667
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_ACCELERATION = 5000.0
MIN_LIMIT = -5.0
MAX_LIMIT = 2520.0
[JOINT_1]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_ACCELERATION = 2500.0
STEPGEN_MAXACCEL = 3125.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -5.0
MAX_LIMIT = 2520.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = -2
[JOINT_2]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -5.0
MAX_LIMIT = 2520.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = -2
[AXIS_Z]
MAX_VELOCITY = 66.66666666666667
MAX_ACCELERATION = 400.0
MIN_LIMIT = -150.0
MAX_LIMIT = 5.0
[JOINT_3]
TYPE = LINEAR
HOME = -10.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 33.333333333333336
MAX_ACCELERATION = 200.0
STEPGEN_MAXVEL = 41.67
STEPGEN_MAXACCEL = 250.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 392.1569
MIN_LIMIT = -150.0
MAX_LIMIT = 5.0
HOME_OFFSET = 5.000000
HOME_SEARCH_VEL = 8.333333
HOME_LATCH_VEL = 8.333333
HOME_FINAL_VEL = -8.333333
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Generated by PNCconf at Sun Jan 26 20:35:25 2025
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=0xxxxxxx"
setp [HMOT](CARD0).watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.s
loadrt plasmac
addf [HMOT](CARD0).read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.y2.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf plasmac servo-thread
addf [HMOT](CARD0).write servo-thread
setp [HMOT](CARD0).dpll.01.timer-us -50
setp [HMOT](CARD0).stepgen.timer-number 1
# ---PLASMA INPUT DEBOUNCE---
#values for these are in custom.hal
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float servo-thread
addf db_ohmic servo-thread
addf db_breakaway servo-thread
addf db_arc-ok servo-thread
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
# ---PLASMA INPUTS---
# ---all modes---
net plasmac:float-switch => db_float.in
net plasmac:breakaway => db_breakaway.in
net plasmac:ohmic-probe => db_ohmic.in
net plasmac:ohmic-sense-in => plasmac.ohmic-sense-in
# ---modes 0 & 1
net plasmac:arc-voltage-in => plasmac.arc-voltage-in
# ---modes 1 & 2
net plasmac:arc-ok-in => db_arc-ok.in
# ---mode 2
net plasmac:move-up <= plasmac.move-up
net plasmac:move-down <= plasmac.move-down
# ---PLASMA OUTPUTS---
# ---all modes---
net plasmac:ohmic-enable <= plasmac.ohmic-enable
net plasmac:scribe-arm <= plasmac.scribe-arm
net plasmac:scribe-on <= plasmac.scribe-on
# external output signals
# --- PLASMAC:TORCH-ON ---
net plasmac:torch-on => [HMOT](CARD0).ssr.00.out-00
# external input signals
# --- ESTOP-EXT ---
net estop-ext <= [HMOT](CARD0).gpio.000.in_not
# --- BOTH-HOME-X ---
net both-home-x <= [HMOT](CARD0).gpio.001.in_not
# --- BOTH-HOME-Y ---
net both-home-y <= [HMOT](CARD0).gpio.002.in_not
# --- BOTH-HOME-Y2 ---
net both-home-y2 <= [HMOT](CARD0).gpio.003.in_not
# --- BOTH-HOME-Z ---
net both-home-z <= [HMOT](CARD0).gpio.004.in_not
# --- PLASMAC:FLOAT-SWITCH ---
net plasmac:float-switch <= [HMOT](CARD0).gpio.005.in_not
# --- PLASMAC:BREAKAWAY ---
net plasmac:breakaway <= [HMOT](CARD0).gpio.006.in_not
# --- Encoder ---
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.012700
net x-index-enable => pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp [HMOT](CARD0).stepgen.01.dirsetup [JOINT_0]DIRSETUP
setp [HMOT](CARD0).stepgen.01.dirhold [JOINT_0]DIRHOLD
setp [HMOT](CARD0).stepgen.01.steplen [JOINT_0]STEPLEN
setp [HMOT](CARD0).stepgen.01.stepspace [JOINT_0]STEPSPACE
setp [HMOT](CARD0).stepgen.01.position-scale [JOINT_0]STEP_SCALE
setp [HMOT](CARD0).stepgen.01.step_type 0
setp [HMOT](CARD0).stepgen.01.control-type 1
setp [HMOT](CARD0).stepgen.01.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.01.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output => [HMOT](CARD0).stepgen.01.velocity-cmd
net x-pos-fb <= [HMOT](CARD0).stepgen.01.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => [HMOT](CARD0).stepgen.01.enable
# ---setup home / limit switch signals---
net both-home-x => joint.0.home-sw-in
net both-home-x => joint.0.neg-lim-sw-in
net both-home-x => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror 0.012700
net y-index-enable => pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp [HMOT](CARD0).stepgen.03.dirsetup [JOINT_1]DIRSETUP
setp [HMOT](CARD0).stepgen.03.dirhold [JOINT_1]DIRHOLD
setp [HMOT](CARD0).stepgen.03.steplen [JOINT_1]STEPLEN
setp [HMOT](CARD0).stepgen.03.stepspace [JOINT_1]STEPSPACE
setp [HMOT](CARD0).stepgen.03.position-scale [JOINT_1]STEP_SCALE
setp [HMOT](CARD0).stepgen.03.step_type 0
setp [HMOT](CARD0).stepgen.03.control-type 1
setp [HMOT](CARD0).stepgen.03.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.03.maxvel [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-vel-cmd <= joint.1.vel-cmd
net y-output => [HMOT](CARD0).stepgen.03.velocity-cmd
net y-pos-fb <= [HMOT](CARD0).stepgen.03.position-fb
net y-pos-fb => joint.1.motor-pos-fb
net y-enable <= joint.1.amp-enable-out
net y-enable => [HMOT](CARD0).stepgen.03.enable
net both-home-y => joint.1.home-sw-in
net both-home-y => joint.1.neg-lim-sw-in
net both-home-y => joint.1.pos-lim-sw-in
# Tandem AXIS Y2 JOINT 2
setp pid.y2.Pgain [JOINT_2]P
setp pid.y2.Igain [JOINT_2]I
setp pid.y2.Dgain [JOINT_2]D
setp pid.y2.bias [JOINT_2]BIAS
setp pid.y2.FF0 [JOINT_2]FF0
setp pid.y2.FF1 [JOINT_2]FF1
setp pid.y2.FF2 [JOINT_2]FF2
setp pid.y2.deadband [JOINT_2]DEADBAND
setp pid.y2.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.y2.error-previous-target true
setp pid.y2.maxerror 0.012700
net y2-index-enable => pid.y2.index-enable
net y2-enable => pid.y2.enable
net y2-pos-cmd => pid.y2.command
net y2-pos-fb => pid.y2.feedback
net y2-output <= pid.y2.output
# Step Gen signals/setup for tandem axis
setp [HMOT](CARD0).stepgen.02.dirsetup [JOINT_2]DIRSETUP
setp [HMOT](CARD0).stepgen.02.dirhold [JOINT_2]DIRHOLD
setp [HMOT](CARD0).stepgen.02.steplen [JOINT_2]STEPLEN
setp [HMOT](CARD0).stepgen.02.stepspace [JOINT_2]STEPSPACE
setp [HMOT](CARD0).stepgen.02.position-scale [JOINT_2]STEP_SCALE
setp [HMOT](CARD0).stepgen.02.step_type 0
setp [HMOT](CARD0).stepgen.02.control-type 1
setp [HMOT](CARD0).stepgen.02.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.02.maxvel [JOINT_2]STEPGEN_MAXVEL
net y2-pos-cmd <= joint.2.motor-pos-cmd
net y2-vel-cmd <= joint.2.vel-cmd
net y2-output => [HMOT](CARD0).stepgen.02.velocity-cmd
net y2-pos-fb <= [HMOT](CARD0).stepgen.02.position-fb
net y2-pos-fb => joint.2.motor-pos-fb
net y2-enable <= joint.2.amp-enable-out
net y2-enable => [HMOT](CARD0).stepgen.02.enable
net both-home-y2 => joint.2.home-sw-in
net both-home-y2 => joint.2.neg-lim-sw-in
net both-home-y2 => joint.2.pos-lim-sw-in
# AXIS Z JOINT 3
setp pid.z.Pgain [JOINT_3]P
setp pid.z.Igain [JOINT_3]I
setp pid.z.Dgain [JOINT_3]D
setp pid.z.bias [JOINT_3]BIAS
setp pid.z.FF0 [JOINT_3]FF0
setp pid.z.FF1 [JOINT_3]FF1
setp pid.z.FF2 [JOINT_3]FF2
setp pid.z.deadband [JOINT_3]DEADBAND
setp pid.z.maxoutput [JOINT_3]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.012700
net z-index-enable => pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp [HMOT](CARD0).stepgen.00.dirsetup [JOINT_3]DIRSETUP
setp [HMOT](CARD0).stepgen.00.dirhold [JOINT_3]DIRHOLD
setp [HMOT](CARD0).stepgen.00.steplen [JOINT_3]STEPLEN
setp [HMOT](CARD0).stepgen.00.stepspace [JOINT_3]STEPSPACE
setp [HMOT](CARD0).stepgen.00.position-scale [JOINT_3]STEP_SCALE
setp [HMOT](CARD0).stepgen.00.step_type 0
setp [HMOT](CARD0).stepgen.00.control-type 1
setp [HMOT](CARD0).stepgen.00.maxaccel [JOINT_3]STEPGEN_MAXACCEL
setp [HMOT](CARD0).stepgen.00.maxvel [JOINT_3]STEPGEN_MAXVEL
net z-pos-cmd <= joint.3.motor-pos-cmd
net z-vel-cmd <= joint.3.vel-cmd
net z-output => [HMOT](CARD0).stepgen.00.velocity-cmd
net z-pos-fb <= [HMOT](CARD0).stepgen.00.position-fb
net z-pos-fb => joint.3.motor-pos-fb
net z-enable <= joint.3.amp-enable-out
net z-enable => [HMOT](CARD0).stepgen.00.enable
net both-home-z => joint.3.home-sw-in
net both-home-z => joint.3.neg-lim-sw-in
net both-home-z => joint.3.pos-lim-sw-in
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
setp hm2_7i96.0.encoder.00.counter-mode 1
setp hm2_7i96.0.encoder.00.filter 1
setp hm2_7i96.0.encoder.00.scale -1
net plasmac:arc-voltage-in hm2_7i96.0.encoder.00.velocity => plasmac.arc-voltage-in
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-in
# ---QTPLASMAC TOOLCHANGE PASSTHROUGH---
net tool:change iocontrol.0.tool-change => iocontrol.0.tool-changed
net tool:prep iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
# ---COMMON PLASMAC DEBOUNCE---
# for the float and ohmic inputs each increment in delay is
# is a 0.001mm (0.00004") increase in any probed height result
setp db_float.delay 5
# set to zero if using internal ohmic sensing
setp db_ohmic.delay 0
setp db_breakaway.delay 5
setp db_arc-ok.delay 5
# The following variables are available for fine tuning some parameters.
# To use any of these, uncomment the required setp line and set an appropriate value.
# Dampen excessive noise on the arc voltage input
# default = 0 (volts)
#setp plasmac.lowpass-frequency 0
# The time delay from losing the arc ok signal until QtPlasmaC reacts to the arc loss.
# default = 0.0 (seconds)
#setp plasmac.arc-lost-delay 0.0
# For mode 0 Arc-OK only, the number of consecutive readings within the threshold that are required to set the Arc-OK signal.
# default = 6
#setp plasmac.arc-ok-counts 6
# For mode 0 Arc-OK only, the maximum voltage deviation that is allowed for a valid voltage to set the Arc OK signal.
#default = 10 (volts)
#setp plasmac.arc-ok-threshold 10
# The voltage above and below 0V that will display as 0V. Prevents small fluctuations from flickering the voltage display.
#setp plasmac.zero-window 0
# The distance (in millimeters) away from the Z MAX_LIMIT that QtPlasmaC will allow the Z axis to travel while under machine control.
# default = 5 (mm)
#setp plasmac.max-offset 5
# The required number of consecutive times that the threshold has been exceeded before applying the void lock to the THC.
# default = 2
#setp plasmac.kerf-error-max 2
# ---OHMIC SENSE CONTACT DEBOUNCE---
setp plasmac.ohmic-sense-off-delay 3
setp plasmac.ohmic-sense-on-delay 3
[EMC]
MACHINE = T17
DEBUG = 0
VERSION = 1.1
[DISPLAY]
INTRO_TIME = 5
GEOMETRY = xyz
CYCLE_TIME = 100
[FILTER]
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
[HMOT]
CARD0=hm2_7i96.0
[HAL]
HALUI = halui
HALFILE = T17.hal
[HALUI]
[KINS]
JOINTS = 4
[TRAJ]
SPINDLES = 3
COORDINATES = XYYZ
LINEAR_UNITS = mm
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_X]
MIN_LIMIT = -5.0
MAX_LIMIT = 1300.0
[JOINT_0]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -5.0
MAX_LIMIT = 1300.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
[AXIS_Y]
MIN_LIMIT = -5.0
MAX_LIMIT = 2520.0
[JOINT_1]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -5.0
MAX_LIMIT = 2520.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = -2
[JOINT_2]
TYPE = LINEAR
HOME = 10.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -5.0
MAX_LIMIT = 2520.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = -2
[AXIS_Z]
MIN_LIMIT = -150.0
MAX_LIMIT = 5.0
[JOINT_3]
TYPE = LINEAR
HOME = -10.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
MIN_LIMIT = -150.0
MAX_LIMIT = 5.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
loadrt hostmot2
loadrt plasmac
# ---all modes---
# ---modes 0 & 1
# ---modes 1 & 2
# ---mode 2
# ---all modes---
# --- ESTOP-EXT ---
# --- Encoder ---
# AXIS X JOINT 0
# AXIS Y JOINT 1
# AXIS Z JOINT 3
# default = 6
# default = 5 (mm)
# default = 2
Last edit: 02 Feb 2025 01:01 by RNJFAB.
02 Feb 2025 01:18 #320391
So the 9v battery tells you it's working, The light in the board should flash faster at 9 volts
Make sure the scaling link on the board is set to 1/32. Next step is to check the encoder velocity in halshow. It should be hovering around the 0 volt frequency (1/32 thereof). if not, debug the reason
There are some encoder settings in hal but they appear to be set OK
Next step is to ensure the thcad calibration settings are set for qtplasmac. There is a link to an online calculator to determine the correct settings in the QTplasmac docs.
- RNJFAB
02 Feb 2025 05:05 - 02 Feb 2025 05:23 #320402
by RNJFAB
So i have done the calculator, and fudged the numbers to get the voltage back around 0v
Confirm - 1/32 setting on board.
Confirm - Plasma is set to 20:1.
Confirm - torch starts and the light on the THCAD 10 flashes faster.
Last edit: 02 Feb 2025 05:23 by RNJFAB.
02 Feb 2025 06:01 #320405
Well the THCAD data is in hal so you are nearly there
what have you got set for
Voltage scale and voltage offset here?
linuxcnc.org/docs/stable/html/plasma/qtp...lasma:parameters-tab
Maybe PCW can see something missing on the night shift...
Time to create page: 0.618 seconds
