Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
- NWE
- Thank you received: 81
13 Feb 2026 22:45 #342918
by NWE
Replied by NWE on topic Ursviken Pullmax Optima 130 press brake retrofit with 4 axis backgage
Finally, got to test drive the pullmax_optima component with closed loop PID, only p set to 5. Left and right side sync nicely, but with loud groaning noise. This machine runs smooth and quiet when I run it open loop. I think what I'm seeing in halscope is a combination of untuned PID and non-linear hydraulics.
chan. 1 pwmgen.04.value = controls left ram servo valve (driven by j3.vel_pid.output)
chan. 2 pwmgen.05.value = controls right ram servo valve (driven by j4.vel_pid.output)
chan. 3 pwmgen.06.value = controls tonnage proportional valve; ultimately comes from a slider on my test gui.
chan. 4,5,6,9 are the discrete spool valve coil power outputs (cr-200 to cr-203)
chan. 7 j3-motor-pos-cmd ultimately comes from a slider on my test gui. This is the input to the pos_pid.command
chan. 8 j3-motor-vel-cmd is signal connecting pos_pid.output => vel_pid.command
I was hoping velocity PID will allow me to skip the low frequency dither these valves like; but now I'm thinking my lack of that dither is what is fighting my PID. I will try lowering the p value first in case 5 is actually too high, next step is adding that low frequency dither, probably via siggen or a custom component.
- NWE
20 Jul 2026 18:34 #347886
by NWE
Finally got back to this project last week. So it seems the big difficulty is the unique hydraulic configuration. The left and right side (axis Y1 and Y2) are servo valves tee'd from the pump. The flow divider is fully emulated electronically. In this case directly in LinuxCNC hal. I seem to have improved control at this point. More testing...
The following user(s) said Thank You: EW_CNC
- NWE
22 Jul 2026 02:28 #347942
by NWE
This works. Today I bent a 1.5" x 10" x 3/16" pc. of steel at 90 degrees. Some more loose ends then I will share the config. I am starting to plan the gui for it. I ended up with two position pid's, one per side, then one sync pid for correcting the tilt between left and right sides. The sync pid has a commanded value = 0 and gets its feedback from the difference between Y1 and Y2 then acts by slowing the one that is ahead.
