Touch Screen Recommendations
- eman5oh
- Thank you received: 11
- emcPT
- Thank you received: 95
It have a very good quality screen.
- eman5oh
- eFalegname
- Thank you received: 30
I am using Asus VT207N with success.
and a very reasonable price under 300€...
- jwsigler
- cncnoob1979
- Thank you received: 75
- Muzzer
- Thank you received: 42
- cncnoob1979
What is a resistive touchscreen?
Resistive touchscreens work on the basis of pressure applied to the screen. A resistive screen consists of a number of layers. When the screen is pressed, the outer later is pushed onto the next layer — the technology senses that pressure is being applied and registers input. Resistive touchscreens are versatile as they can be operated with a finger, a fingernail, a stylus or any other object.
www.goodgearguide.com.au/article/355922/...istive_touchscreens/
For the price I'm going to try and make it work for me. I would have preferred for a capacitive touchscreen.
- Thank you received: 4645
Is resistive OK? I thought capacitive would be better
I have a resistive on my Mill and just fitted one to the lathe. I would have preferred capacitive just because the glass front it easier to clean. However the resistive ones work fine.
- eman5oh
