Install current master 2.8
24 Aug 2019 11:16 - 24 Aug 2019 19:02 #143082
by FedX
Replied by FedX on topic Install current master 2.8
i have to update to 2.8 or 2.9 because i want to use the gantry homing and the compensation for ballscrews because i have two 1600mm screws on my Y Axis and they have no linear diviation to each other.
I installed linuxcnc ccompletely new with the 2.7.14 wheezy iso. I went to synaptics and deactivated the 2.7 base from linuxcnc.org and activated both master files from buildbot.
Then i click refresh, but it still shows 2.7.14 as newest version.. now iam stuck and dont know what to do. Also i get a failure when i refresh "Release-Datei für archive.debian.org/debian-security/dists/wheezy/updates/Release ist abgelaufen"
it says something that debian release has expired..
It finally worked i checked only the files from buildbot and unchecked all other packages. But the new Master branch is 2.9. There is a 2.8 Version at scratch but i think thats not the latest ? Where can i get the latest stable version of 2.8 or is 2.9 also stable?
Last edit: 24 Aug 2019 19:02 by FedX.
24 Aug 2019 20:47 #143110
Replied by rodw on topic Install current master 2.8
V2.8 has been quarantined off for final checking pending it becoming the release version when it will retire V 2.7 There is not much difference between 2.8 and 2.9 but V 2.9 is open for business for new features
25 Aug 2019 09:53 #143126
by vre
Replied by vre on topic Install current master 2.8
any news about python-gtksourceview2 & python-vte dependencies
that has linuxcnc 2.8 ?
In debian buster python-gtksourceview2 & python-vte are not available as packages
so 2.8 cannot be installed and if you force install without these deps gmocappy does not works because it depends to python-gtksourceview2
25 Aug 2019 10:59 #143129
That is not something in my sphere but I had no problems compiling V2.9 from source today.
26 Aug 2019 19:09 #143243
Use the Stretch ISO instead, install the 2.7 uspace ISO then update to 2.8 from the Buildbot:
www.linuxcnc.org/downloads/
Replied by andypugh on topic Install current master 2.8
- Thank you received: 5938
26 Aug 2019 19:24 #143247
Replied by tommylight on topic Install current master 2.8
There seems to be an error on that page in regards to stretch, 2.7.0 in the title but talks about 2.8 in the description.
27 Aug 2019 05:57 #143284
by vre
python-vte deps and these packages does not exist in debian buster.
(i have compiled deb packages from src)
compiling has no problem installing has problem because has python-gtksourceview2,That is not something in my sphere but I had no problems compiling V2.9 from source today.
Time to create page: 0.326 seconds
