4th axis tangent to path XY
11 years 1 week ago #63999 by mgenton85
Has there been any further dev on tangential path follow or does anyone know of a cam program that will give the c axis output with xyza ?
11 years 1 week ago #64002 by andypugh
mgenton85 wrote: Has there been any further dev on tangential path follow or does anyone know of a cam program that will give the c axis output with xyza ?
From a quick Google it seems that Gcodetools (a plug-in for Inkscape) can do this.
An alternative would be an input filter for LinuxCNC. This would take normal XY G-code and add additional C-axis moves.
11 years 1 week ago #64005 by mgenton85
yeah that makes no sense to me :( i tried to use the tangentkins with 2.6.4 but all that happens is joint 3 following error and i dont really understand the language yet
if tangentkins worked that would be ideal can you provide a helpful link so i can decode and learn your program? because i really need to have this capability and i refuse to go back to mach mach 60 ipm with steppers linux 200 ipm same setup except for encoders yeah not going backwards
11 years 1 week ago #64006 by andypugh
mgenton85 wrote: can you provide a helpful link so i can decode and learn your program?
Can you re-phrase the question? I am not sure what you mean.
11 years 1 week ago - 11 years 1 week ago #64008 by mgenton85
i dont know the lanuage that the tangentkins is wrote in i also dont know where all the variables come from and what they do is there a list that explains what variables there are and what they do so i can work backwards and understand tangentkins ?
with the trajectory planner is there way to link the direction of movement to a c axis?
(side notefor those who dont know what i am aking about) infosys.beckhoff.com/english.php?content...axistracking.htm&id=
Last edit: 11 years 1 week ago by mgenton85.
11 years 1 week ago #64011 by andypugh
Tangentkins is written in C.
To avoid C-axis following errors the simplest solution is to set the f-error limits very wide. There are no trajectory limits on the C-axis with tangentkins.
I don't think that tangentkins is a good solution.
linuxcnc.org/docs/html/motion/kinematics.html
Time to create page: 0.253 seconds
