4th axis tangent to path XY
4 years 3 months ago #248162 by rajsekhar
Hello friends,
I need to use tangential and decided to make a trial for "tangentkins.c"
I got the file. But, as I am not a computer expert, please guide me how to install.
My Linuxcnc version is attached in photo.
4 years 3 months ago #248190 by andypugh
"sudo halcompile ---install tangentkins"
Should compile and install it. But it doesn't work very well.
4 years 3 months ago #248213 by rajsekhar
raycnc1@debian:~$ sudo halcompile --install tangentkins.c
[sudo] password for raycnc1:
  File "/usr/bin/halcompile", line 1508, in <module>
    main()
  File "/usr/bin/halcompile", line 1492, in main
    shutil.copy(f, tempdir)
  File "/usr/lib/python2.7/shutil.py", line 139, in copy
    copyfile(src, dst)
  File "/usr/lib/python2.7/shutil.py", line 96, in copyfile
    with open(src, 'rb') as fsrc:
IOError: [Errno 2] No such file or directory: 'tangentkins.c'
raycnc1@debian:~$
the above result happened while installing.
which folder tangentkins.c should be placed to succeed?
4 years 3 months ago #248224 by rajsekhar
Dear Andy,
I finally installed tangentkins.c and tangentkins.so generated (photo attached).
My machine is a XYZA configuration. Actually I modified tangentkins.c (attached) to C axis before installtion. But no Ca xis (joint 6) pin shows.
what to do next?? Kindly help.
4 years 3 months ago #248230 by andypugh
Either have JOINTS = 6 in your INI, or put the C axis on joint 3 in the kinematics.
LinuxCNC separates the joins and the axes, C might be 6th in the sequence, but as you have no A or B it is the 4th joint. (index 3, as the first joint / X is Joint 0)
4 years 3 months ago #248263 by rajsekhar
Well, I left the C axis option and shifted to XYZA configuration to test the tangentkins. Actually C axis could not be configured, however I will solve that later.
Now, I installed the Andy's Tangentkins.C file (attached). tangentkins.so generated.
Entered loadrt tangentkins in in HAL .
In custom hal, setp tangentkins.auto 1.
HAL pin tangentkins.auto is showing active in HAL watch, yellow round signal.
But If I jog, x or Y or X-Y both, A axis does not move. Atleast the DRO in Gmoccapy does not show any reading.
How to solve??
HAL, Custom.hal, ini file attached.
Time to create page: 0.294 seconds
