4th axis tangent to path XY
4 years 3 months ago #248272 by andypugh
You will need to home the system first before kinematics will become active.
4 years 3 months ago #248273 by andypugh
(setting kinstype to "IDENTITY" might fix this, but homing is going to be needed anyway or the C axis will point in a random direction)
4 years 3 months ago #248297 by rajsekhar
Dear Andy,
I homed all the axes. Basically I am trying on a computer which does not have a machine connected to it. so just clicked the homing buttons for the axes one by one.
But No luck. The A axis DRO on screen does not show any movement for X-Y movements.
The A axis can be jooged from jog button and tangentkins.c is active.
4 years 3 months ago #248305 by andypugh
You might not see anything on the DRO for the A axis. You are not commanding any A _axis_ moves. _Joint 3_ is being adjusted to keep a constant A angle (of zero) between the path direction and the cutter.
The place to look is in HAL. Open a halmeter to look at the pin joint.3.motor-pos-cmd. That is the pin that will control the motor.
4 years 3 months ago #248344 by rajsekhar
Please refer the attached photo.
No change in joint.3.motor-pos-cmd pin.
4 years 3 months ago #248351 by andypugh
Does it become non-zero if you jog A?
Time to create page: 0.281 seconds
