Controlling temperature of reprap extruder hot-end
04 Oct 2011 10:43 #13641
Replied by andypugh on topic Re:Controlling temperature of reprap extruder hot-end
fma wrote:
As a first guess I would assume that they were exactly the same thing. If that doesn't work, try multiplying by the servo thread period.How do I determine Ki and Kd for the hal pid component, from Ti and Td (integration time and derivative time)?
04 Oct 2011 11:15 #13642
by fma
Replied by fma on topic Re:Controlling temperature of reprap extruder hot-end
Ok, I'll try that.
I just noticed that there is a auto-tune pid component! I'll give it a try to.
Thanks,
Thanks,
05 Oct 2011 18:09 #13686
by fma
I made some tests with the at_pid component: I don't get good results.
I noticed one thing which may be an issue in my case: the pid output goes from -max to + max. When the feedback is higher than the command, the output goes to négative values.
In my case, negatives values have no effect, as the pid output is connected to a pwm. But the pid thinks it can 'brake', which is not the case, as it could be with a servo motor.
Is there a way to tell the pid that the minimum value it can use is 0?
12 Oct 2011 06:51 #13853
by fma
No idea?
12 Oct 2011 08:03 #13854
Replied by cmorley on topic Re:Controlling temperature of reprap extruder hot-end
I can't see how to stop pid at zero.
how about using a limit component or absolute component.
or write your own PID component.
12 Oct 2011 08:15 #13856
by fma
I can't truncate, as the at-pid comp still think it can reach -max value, but I just need to match the at_pid output (from -max to +max) with my pwmgen input, with scale and other comps.
Thanks!
Thanks!
Time to create page: 0.157 seconds
