Also keep in mind the original motors are 5 wire motors and you may have trouble finding drives to run them
Yes. Which sounds like it might be easier if you don't have a way to make adapter plates.So I shouldn't have trouble running the original motors, as long as I don't mind the original slower speed?
The main constraint is, no USB. It has too high a latency (and the USB-parallel convertors don't give a proper parallal port, they are only useful for printers as the pins are not (typically) individually addressableAs far as the computer is concerened, what are the constraints? For example, could I use on of my laptops and just buy a pair of USB-> DB25 parallel adapters?.
