Have a look at this thread:
forum.linuxcnc.org/49-basic-configuratio...-loop-setup?start=20
I think Hakan is using the same board setup that you are and he has posted his HAL and INI files. You should be able to see the required "loadrt hm2_eth_board_ip=" line that pics the needed firmware and associated parameters.
I have not gotten to the ethernet side of things myself. I'm still using PCI based kit.
Cheers.
