Trying to configure XYZU 4 axis setup.
You _might_ need JOINTS=7 too, but that was a sort-of bug and might have been fixed.
Also, the display movement for U seems to be moving on the X axis, that's really not an issue but if the U movement could be hidden from the screen the display would be accurate when viewing.
U is assumed to be a second joint parallel to X.I seem to be getting closer but still a no go. EMC will start now and show a U axis. When I try to jog it it shows movement on screen and in the DRO but the motor does not move.
You can probably remove it by specifying GEOMETRY=XYZ in the INI (I can't recall which section, but it is in the INI file config docs)
You probably don't have the correct stepen linked to axis.6.motor-pos-cmd etc in the HAL file. You are likely to need to link axis.6 pins to stepgen.3 pins.
If you don't sort it yourself, post your hal file, sounds like not connected up properly
OK, keep in mind I've been trying all kinds of things. At this point the display shows movement but no motor movement.[Edit]Yeah Andy beat me to it.
HAL file
# Generated by stepconf at Mon Aug 20 11:49:59 2012
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
loadrt stepgen step_type=0,0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
net coolant-mist <= iocontrol.0.coolant-mist
net probe-in => motion.probe-input
setp parport.0.pin-02-out-invert 1
net xdir => parport.0.pin-02-out
setp parport.0.pin-03-out-invert 1
net xstep => parport.0.pin-03-out
setp parport.0.pin-04-out-invert 1
net ydir => parport.0.pin-04-out
setp parport.0.pin-05-out-invert 1
net ystep => parport.0.pin-05-out
net zdir => parport.0.pin-06-out
setp parport.0.pin-07-out-invert 1
net zstep => parport.0.pin-07-out
setp parport.0.pin-08-out-invert 1
net Udir => parport.0.pin-08-out
net Ustep => parport.0.pin-09-out
net coolant-mist => parport.0.pin-14-out
net home-x <= parport.0.pin-10-in
net probe-in <= parport.0.pin-11-in-not
net home-y <= parport.0.pin-12-in
net estop-ext <= parport.0.pin-13-in
net home-z <= parport.0.pin-15-in-not
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 1
setp stepgen.0.dirhold 38000
setp stepgen.0.dirsetup 38000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net home-x => axis.0.home-sw-in
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 1
setp stepgen.1.dirhold 38000
setp stepgen.1.dirsetup 38000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
net home-y => axis.1.home-sw-in
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 1
setp stepgen.2.dirhold 38000
setp stepgen.2.dirsetup 38000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net home-z => axis.2.home-sw-in
#setp stepgen.6.position-scale [AXIS_3]SCALE
# setp stepgen.3.steplen 1
# setp stepgen.3.stepspace 1
# setp stepgen.3.dirhold 38000
# setp stepgen.3.dirsetup 38000
# setp stepgen.6.maxaccel [AXIS_3]STEPGEN_MAXACCEL
# net upos-cmd axis.6.motor-pos-cmd => stepgen.3.position-cmd
net Upos axis.6.motor-pos-cmd => axis.6.motor-pos-fb
# net ustep <= stepgen.3.step
# net udir <= stepgen.3.dir
net uenable axis.6.amp-enable-out => stepgen.3.enable
net estop-ext => iocontrol.0.emc-enable-in
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
and change stepgen.6 to stepgen.3.
and AXIS_3 to AXIS_6
Here's the latest on the [AXIS_6] HAL file
setp stepgen.3.position-scale [AXIS_6]SCALE
setp stepgen.3.maxaccel [AXIS_6]STEPGEN_MAXACCEL
net upos axis.6.motor-pos-cmd => axis.6.motor-pos-fb
Thanks, now EMC will start and the GUI shows movement for U but the motor still doesn't turn.A typo or you still have the SCALE commented out in your ini file. [AXIS_6]SCALE in your hal file means look in the ini file for section [AXIS_6] and find SCALE the insert that value here.
I'm attaching the entire config folder and stepconf file, maybe that will help you find the issue.
