4 axis cnc winch style foam hotwire configuration
05 Oct 2012 20:46 #25022
by BigJohnT
Replied by BigJohnT on topic Re:4 axis cnc winch style foam hotwire configuration
Did you add halui?
05 Oct 2012 20:51 #25024
by mt92
Replied by mt92 on topic Re:4 axis cnc winch style foam hotwire configuration
Thanks Big John. I renamed my original ini to backup ini, then renamed the hot winch ini to my-mill and it comes up. I am sure I will have more question when editing the files.
Thanks mike
Thanks mike
05 Oct 2012 20:54 #25025
by BigJohnT
I'm so glad you got it up and going... at tip for dmesg if you redirect it to a file (the > does the magic) and attach it to the message it is easier for old eyes to read.
dmesg > myerror.txt
05 Oct 2012 20:56 #25026
by mt92
Cool thanks.
05 Oct 2012 21:17 #25028
by mt92
Is there an easy way to take the setting I need from my hal file I created with stepgen and transfer them to the hotwinch hal?
05 Oct 2012 21:24 - 05 Oct 2012 21:25 #25029
by BigJohnT
Copy and paste...
You might want to read this first so what your copying and pasting makes some sense.
linuxcnc.org/docs/html/hal/basic_hal.html
Last edit: 05 Oct 2012 21:25 by BigJohnT.
07 Oct 2012 11:37 #25093
by mt92
I have the machine moving in joint and in world. But in world the stepper motors are noisy. I would like to switch my measurement units over to inches if that's possible. I will attach my files. Any help would be appreciated.
Below is my hal file.
Mike
Mike
07 Oct 2012 11:38 #25094
by mt92
This is my Modified ini file
07 Oct 2012 11:39 #25095
by mt92
This is the file to have xy on the right two motors. I think?
07 Oct 2012 11:43 #25096
by mt92
This is the hal created with step wizard.
Time to create page: 0.226 seconds
