Resolver Output
09 Oct 2012 18:38 #25177 by andypugh
Replied by andypugh on topic Re:Resolver Output
Does the angle ever go to zero?
I have looked at the changes I made, and they shouldn't affect the angle pin at all.
How are you forcing index-enable to true?
Can you create a halscope plot of the angle / counts with the spindle turning at steady speed?
(It is possible to save a halscope trace to file as data)
09 Oct 2012 19:38 #25180 by LAIR82
Replied by LAIR82 on topic Re:Resolver Output
Hello Andy,
The angle goes from 0 to 1 and then repeats for every revolution of the chuck. I was mistaken about the linearity, the number readout on "show hal config-watch" was non-linear, but in the halscope it looks ok.
I am going to the show hal config and doing a setp........ true command with the index-enable from the resolver to the motion.index-enable unlinked in my hal file. PCW showed me this to see if the index-enable function was actually working.
I saw the counts resetting at something like 2x10^10 decimal place, so I started adjusting the divisor value to see if it would change but it didn't. I was doing a 1000rpm spindle command, and the counts were resetting every roughly 25 seconds. (counting down from roughly 2000000000 to -20000000000)
Here is that halscope trace file you wanted.
09 Oct 2012 19:55 #25182 by andypugh
OK, it doesn't sound like I broke that bit.
I think I know what the problem might be. (the unsigned counter is being decremented through zero, I didn't think it could be)
Try changing line 325/326 in resolver.c to:
if (++(res->index_cnts) >= res->hal.param.index_div){
res->index_cnts = 0;
10 Oct 2012 12:00 #25197 by LAIR82
Good Morning Andy,
When I got in this morning, I made those changes, and still no difference. I shot an email off to the place I bought the resolver's from to see if they have a different resolver that might cure this. I'm up for anything at this point.
10 Oct 2012 12:23 #25199 by andypugh
I am sure we can make this work, it is just that the development cycle is rather long.
You can save a lot of time by working with a run-in-place version and starting from the command line after . ./scripts/rip-environment.
After the first ./configure / make / sudo make setuid sequence you can re-compile a new version in a few minutes with just "make"
In order to figure out what is going on we can add some debug code. Add the rtapi_print statements below to the resolver.c code and re-make
(You _did_ re-make after the last change?)
     if ((res->old_reg ^ hm2->resolver.position_reg[i]) & 0x80000000){
rtapi_print("wrap. index_cnts = %u\n", res->index_cnts);
rtapi_print("limit\n");
                if (*res->hal.pin.index_enable){
rtapi_print("index_enable. index_enable = %i\n", *res->hal.pin.index_enable);
                    res->offset = res->accum & 0xFFFFFFFF00000000LL;
                    *res->hal.pin.index_enable = 0;
10 Oct 2012 12:24 #25200 by andypugh
I forgot to say, you should then run the code for a few revolutions of the spindle, then look at the output of dmesg.
10 Oct 2012 12:31 #25201 by LAIR82
Actually no, I thought when I made the change to the file it just started using it.
So I need go to the terminal window and go through the motions again an do remake instead of make?
Sorry Andy
10 Oct 2012 12:39 #25202 by andypugh
With Python and TCL files that is the case, but c, cpp and comp file changes need to be compiled.
remake isn't a command :-)
make
sudo make install
Should do the trick.
Leave off doing the rtapi_print changes until we have seen if the first change works.
10 Oct 2012 12:41 #25203 by andypugh
Note that as the last ./configure you did was for an installed system, then that is what a second, third... make will do.
Welcome to the developer learning curve.
10 Oct 2012 14:32 #25209 by LAIR82
IT'S ALIVE,
Works like a dream, when I did the commands.
One of these days I'll get the hang of it.
Thank You Andy
