Following Error When Homing
- Thank you received: 5336
05 Nov 2022 14:55 #256027
Replied by PCW on topic Following Error When Homing
Well, I cannot duplicate that bug...
What specific firmware are you using?
Can you update to the latest master?
Its not likely firmware or LinuxCNC version related
but to debug I need to be able to replicate the issue
05 Nov 2022 17:37 #256034
OK, I _was_ able to replicate the bug
(it only happens when moving slowly),
and think I have it fixed (in master)
The following user(s) said Thank You: tommylight, Clive S, rmu, turbostew
- rmu
- Thank you received: 101
07 Nov 2022 10:40 #256155
by rmu
Replied by rmu on topic Following Error When Homing
That one line fixes it. Thank you.
- turbostew
- Thank you received: 8
07 Nov 2022 16:59 #256171
by turbostew
Replied by turbostew on topic Following Error When Homing
Thanks PCW, all is working now. Had an issue with iocontrol.0.user-request-enable staying false in latest Master (using qt-dragon) but figured out a work around.
07 Nov 2022 18:03 #256176
Sorry for the (very old) bug.
It only shows up when moving slowly and or
with low-res encoders (so you get less than a count per
servo period) so I did not manage to duplicate it earlier
The following user(s) said Thank You: turbostew
Time to create page: 0.798 seconds
