Creating a Script
- BigJohnT
- Thank you received: 1176
16 Feb 2013 01:35 #30131
by BigJohnT
Replied by BigJohnT on topic Creating a Script
Here is the python file. Place it in the directory with a copy of your files you want to convert and make sure you set permissions to execute.
Enjoy
#! /usr/bin/env python
# Usage: ./todd.py filenametoconvert.ngc
# Output: converted_filenametoconvert.ngc
import sys
def main(argv):
openfile = open(argv[0], 'r')
file_in = openfile.readlines()
openfile.close()
file_out = []
for line in file_in:
# print line
if line.find('Z') != -1:
words = line.rstrip('\n')
words = words.split(' ')
newword = ''
for i in words:
if i[0] == 'Z':
newword = 'W'+ i[1:]
if len(newword) > 0:
words.append(newword)
newline = ' '.join(words)
file_out.append(newline)
else:
file_out.append(line)
newfile = open('converted_'+argv[0], 'w')
for item in file_out:
newfile.write("%s\n" % item)
newfile.close()
if __name__ == "__main__":
main(sys.argv[1:])
Enjoy
- BigJohnT
18 Feb 2013 22:31 #30280
by BigJohnT
Todd,
Did this work out for you?
- Thank you received: 1464
18 Feb 2013 23:51 #30286
Replied by Todd Zuercher on topic Creating a Script
I have not had time to test it yet.
19 Feb 2013 02:01 #30291
Ok, where do I save the file? When I try to use it it a window pops ups and sais that the file can not be found.
- BigJohnT
19 Feb 2013 02:12 - 20 Mar 2013 17:27 #30292
by BigJohnT
Save the python file to any directory. Copy a ngc file you wish to convert to the same directory.
Open up a terminal and change directory to the one that contains the two files.
Type in dot slash the python file name and the file name to convert.
For example
For example
cd convert_directory
./todd.py filename.ngc
Last edit: 20 Mar 2013 17:27 by BigJohnT.
20 Mar 2013 03:33 #31617
I can not open the file todd.py.txt
- Thank you received: 5219
20 Mar 2013 03:38 #31618
Replied by PCW on topic Creating a Script
You probably have to remove the .txt from the filename
20 Mar 2013 04:20 #31622
I can't down load it from the web site. It gives an internal server error when clicked on.
20 Mar 2013 07:05 #31626
The forum seems to have misplaced a lot of old attachments, but
the complete text of the program is in a previous post so you
should be able to just copy and paste it into an editor (gedit for example)
20 Mar 2013 08:48 #31630
I've not had any luck getting it to work, and I was hoping that there were some revisions in the last attachment that might clue me in to what I'm doing wrong.
Time to create page: 0.096 seconds
