Creating a Script
- ArcEye
- Thank you received: 758
20 Mar 2013 16:01 #31633
by ArcEye
Replied by ArcEye on topic Creating a Script
Hi
I cut and pasted the code JT posted and it works fine.
One thing I did though, is have the top line read #! /usr/bin/python, because I dont have a python environment setting, I just have the python binary in /usr/bin
This could be your problem, or that you have not chmod 755 todd.py to make the script executable
Attached is a copy in a zip already with mode set etc
Put into a directory, copy over the .ngc file you want to convert to the same directory and run
./todd.py filetoconvert.ngc
- BigJohnT
- Thank you received: 1176
20 Mar 2013 17:29 - 20 Mar 2013 17:31 #31635
by BigJohnT
Luck doesn't have much to do with getting the program to work
Can you be more specific about what the error is?
I uploaded a zipped version and it gives me the internal error too... I wonder what is hosed with the forum database?
Finally this one attached ok... ArcEye I noticed your attachment has a file size of 0.
Replied by BigJohnT on topic Creating a Script
I've not had any luck getting it to work, and I was hoping that there were some revisions in the last attachment that might clue me in to what I'm doing wrong.
Last edit: 20 Mar 2013 17:31 by BigJohnT.
- Thank you received: 1467
20 Mar 2013 19:42 - 20 Mar 2013 21:47 #31638
Replied by Todd Zuercher on topic Creating a Script
It runs now, but it is putting the W codes on a new line instead of at the end of the line. It was also adding a line feed between every line but I was able to stop it from doing that.
Also what changes would I have to make to use this as a filter script when opening a file with linuxCNC.
Not knowing any thing about programming this sure seems harder than it should be.
Last edit: 20 Mar 2013 21:47 by Todd Zuercher.
- ArcEye
21 Mar 2013 00:21 #31644
by ArcEye
I know, but if you download it, it is 492 bytes and as it should be internally
How does that work?
....ArcEye I noticed your attachment has a file size of 0.
21 Mar 2013 02:10 #31646
The output looks like this:
Instead of this:
G1 X2.4367 Y1.4479 Z-0.0827
W-0.0827
G1 X2.4409 Y1.4376 Z-0.0739
W-0.0739
G1 X2.4505 Y1.4109 Z-0.051
W-0.051
G1 X2.4557 Y1.3982 Z-0.0395
W-0.0395
Instead of this:
G1 X2.4367 Y1.4479 Z-0.0827 W-0.0827
G1 X2.4409 Y1.4376 Z-0.0739 W-0.0739
G1 X2.4505 Y1.4109 Z-0.051 W-0.051
G1 X2.4557 Y1.3982 Z-0.0395 W-0.0395
- BigJohnT
21 Mar 2013 07:15 - 21 Mar 2013 07:15 #31653
by BigJohnT
Todd,
It was not adding a line feed when I tested it... I'll look at it in the AM to see what's up.
It's not word wrapping is it?
Last edit: 21 Mar 2013 07:15 by BigJohnT.
21 Mar 2013 20:04 #31673
This is what I had to do to make it stop inserting line feeds
#! /usr/bin/env python
# remove the .txt extension
# Usage: ./todd.py filenametoconvert.ngc
# Output: converted_filenametoconvert.ngc
import sys
def main(argv):
openfile = open(argv[0], 'r')
file_in = openfile.readlines()
openfile.close()
file_out = []
for line in file_in:
# print line
if line.find('Z') != -1:
words = line.rstrip()
words = words.split(' ')
newword = ''
for i in words:
if i[0] == 'Z':
newword = 'W'+ i[1:]
if len(newword) > 0:
words.append(newword)
newline = ' '.join(words)
file_out.append(newline+'\n')
else:
file_out.append(line)
newfile = open('converted_'+argv[0], 'w')
for item in file_out:
newfile.write("%s" % item)
newfile.close()
if __name__ == "__main__":
main(sys.argv[1:])
21 Mar 2013 23:09 #31684
Now all I need to do is figure out how to make this work a filter for loading files in axis.
When I try it now It just says no such file or directory.
- arvidb
- Thank you received: 159
22 Mar 2013 06:50 - 22 Mar 2013 07:10 #31702
by arvidb
Replied by arvidb on topic Creating a Script
Here's another way, using a sed one-liner:
I attached a script using this method as a file to this post. You will have tobefore you can use it. Then use it like this:
Edit: For info on how to set up filters, look here: "www.linuxcnc.org/docs/2.4/html/config_ini_config.html#sub:[FILTER]-Section" (the forum can't handle links with '[' in them, it seems). I believe the script you use will have to generate the modified code to stdout, so BigJohnT's script might not work.
Edit2: Oh, and to avoid having to write an absolute path to the program in your INI-file, doThis makes the script "globally" available without having to say exactly where it is.
sed 's|Z\([-.0-9]*\)|Z\1 W\1|g' $1
$ cd <folder-where-you-downloaded-the-file>
$ gunzip w_add.sh.gz
$ chmod +x w_add.sh
$ ./w_add.sh in-file > out-file
$ sudo cp w_add.sh /usr/bin/
Last edit: 22 Mar 2013 07:10 by arvidb.
The following user(s) said Thank You: Todd Zuercher
26 Mar 2013 08:19 #31887
Ok, this sed script works but...
It will load and convert files saved on the hard drive, but when I try to load a file that was saved on our network I get file not found errors. But files opened from the network that don't go through the script still open fine. Why?
I think I would still like to learn how to modify John's script to work with as an axis filter.
Time to create page: 0.079 seconds
