Hardinge HXL Tool Turret
- microsprintbuilder
- Thank you received: 4
- BigJohnT
- Thank you received: 1176
JT
- BigJohnT
JT
- Thank you received: 4994
When you first start up LinuxCNC it does not know what tool is loaded physically. So you will have to issue a Tn M6 G43 at startup.
There is almost certainly a way of doing this automatically.
Arguably it should be built-in. The way that tools are handled in LinuxCNC is open to some improvement, and we are working on it.
- ArcEye
- Thank you received: 758
What I have done with 3 different toolchanger components that start in an unknown state, is to change iocontrol.
I added a pin to receive the current tool number and a bit flag to trigger an update.
This triggers iocontrol to issue a tool change instruction for the given toolnumber.
Because the tool change component knows that tool is already current, it just returns a toolchanged signal and the toolnumber is automatically updated.
I don't know anything about classic ladder, these were realtime components.
If classic ladder can set HAL pins, the same could be used.
Which is a pretty strong argument for why toolchanger behaviour does not belong hardcoded into iocontrol (and that is on the list of things to change)
- BigJohnT
Any idea why I would have to do it twice? It like it's not updating. When I get home tonight I'm going to print out your files I have and compare them to mine again.
My WAG is your logic is not correct in the ladder. Watch iocontrol.0.tool-changed in a watch window as you change tools. Axis should update as soon as it goes true. Actually put all the iocontrol tool bits in the watch window as you change a tool.
JT
