- Thank you received: 153
New Trajectory Planner - Testers/programs wanted
- skunkworks
This program I have attached would probably be a good program for testing your non-tangent arc work...
rellenberg wrote: This is good news! Is that config for a real machine?
I just pushed a few tweaks that should eliminate some acceleration hiccups. It wasn't handling the tail end of parabolic blends quite right, so there was a subtle stutter. Also, blend radii are a bit larger now to soften the acceleration pulses. When planning a blend arc, it checks what the equivalent-size parabolic blend would be, then allows the arc to be up to that size. Often the equivalent parabolic blend is longer, which means a larger-than-necessary blend radius, and lower accelerations. Of course, everything still obeys assigned tolerances, but hopefully this will be a bit gentler on the machine.
- Thank you received: 2181
Todd Zuercher wrote: Yes, I'm using 10.04.
Are there any instal instructions for the less than gifted at using Linux? (much much less in my case)
just for others:
On that page look for the two libmodbus debs.
click on one and open/run it - it should ask about installing the deb - go ahead and install it.
Do the same for the other cause I'm not sure if you require both - it won't hurt.
Then try linuxcnc compiling again
Chris M
- rellenberg
- Thank you received: 10
Can you post the code and config you're using? There are a few things I can think of that would case a slowdown in general:
- Arcs have lower acceleration, because there were some blending cases that would allow acceleration overages. Right now I just cut the acceleration in half (this is the worst case solution), but there may be room for improvement here.
- I changed Naive CAM to be disabled by default, which may make programs run slower with the same setting. Specifically, G64 P0.005 in the original TP defaults to Q0.005 as well. However, this can in some cases lead to tolerances of up to 0.010", since Naive CAM and blending are both applied. It seemed more logical to make the tolerances be specified explicitly, so that the user knows exactly what they're getting.
Finally, are you running the beta branch or the experimental branch? I have made a bunch of minor improvements in the experimental branch, so you may see more improvement there.
Thanks for trying it out!
-Rob
- Thank you received: 1480
What do I have to do different to try the Experimental branch?
Here is the code I was running (I don't think it has any arc segments)
And the machine config. (it is a large 3 axis gang router with 8 spindles, the modbus mess is for the spindle controls)
- skunkworks
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 1
ARC_BLEND_OPTIMIZATION_DEPTH = 50
ARC_BLEND_SMOOTHING_THRESHOLD = 0.4
Old TP - 25min - 16sec
New TP - 18min - 30sec
- skunkworks
Cool beans!
sam
