New Trajectory Planner - Testers/programs wanted
- Paul
12 years 7 months ago #45216
by Paul
Replied by Paul on topic New Trajectory Planner - Testers/programs wanted
I tried to get the latest, but am receiving the error:
cnc@linuxcnc:~/linuxcnc-rc1$ git branch --track circular-blend-arc-rc1 origin/circular-blend-arc-rc1
fatal: Not a valid object name: 'origin/circular-blend-arc-rc1'.
I received this after following the new instructions found in the first post. I have a version I downloaded sometime in early February loaded in linuxcnc-beta which went well.
Any help appreciated. Thanks.
Paul
Paul
- skunkworks
- Thank you received: 153
12 years 7 months ago #45229
by skunkworks
Replied by skunkworks on topic New Trajectory Planner - Testers/programs wanted
well - crap. I thought I had edited the first post.. Rob did some work to get his branch to work in current master so he is up to rc3. (rc1 was deleted it seems)
Could you try instead.
git branch --track circular-blend-arc-rc3 origin/circular-blend-arc-rc3
git checkout circular-blend-arc-rc3
cd src
./autogen.sh
./configure --enable-run-in-place
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcnc
cd src
./autogen.sh
make
sudo make setuid
cd ..
linuxcnc
Paul wrote: I tried to get the latest, but am receiving the error:
Paul
The following user(s) said Thank You: Paul
- Paul
12 years 7 months ago #45260
by Paul
That did it! Thanks. Sorry I couldn't figure it out on my own.
- ldwilson46
12 years 7 months ago #45400
by ldwilson46
Replied by ldwilson46 on topic New Trajectory Planner - Testers/programs wanted
I'm having trouble getting the rc3 download to compile & would appreciate some pointers -
environment -
new (5/28/14) iso download system install.
source from github.com (git.linuxcnc.org was busy every time I tried). source version was master, per the incantations prescribed on the download page.
master branch compiled without complaint.
today, I pulled the rc3 branch per the instructions on page 1 of this thread & launched the usual make process. make stopped with
(much compilation)
touch po/linuxcnc.pot
cp emc/kinematics/tc.h ../include/tc.h
cp: cannot stat `emc/kinematics/tc.h': No such file or directory
make: *** [../include/tc.h] Error 1
when I looked, the include directory contained a tc.h file. to investigate, I copied that file to src/emc/kinematics, reran make, and got
( again, much makery)
CC [M] /home/techno/lcnc-dev/src/emc/tp/blendmath.o
CC [M] /home/techno/lcnc-dev/src/emc/motion/motion.o
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
In file included from /home/techno/lcnc-dev/src/emc/motion/motion_debug.h:19,
from /home/techno/lcnc-dev/src/emc/motion/motion.c:19:
/home/techno/lcnc-dev/src/emc/kinematics/tc.h:36: error: conflicting types for ‘PmLine9’
/home/techno/lcnc-dev/src/emc/tp/tc_types.h:59: note: previous declaration of ‘PmLine9’ was here
/home/techno/lcnc-dev/src/emc/kinematics/tc.h:42: error: conflicting types for ‘PmCircle9’
( many more type errors)
so, clearly just moving the file ain't the answer ( I didn't expect it would be).
Anyone have a clue why a download from yesterday isn't compatible with the fresh system install?
I haven't seen any refs to later versions than rc3 - did I miss a later release?
thanks in advance
-ldw
environment -
(much compilation)
thanks in advance
-ldw
- rellenberg
- Thank you received: 10
12 years 7 months ago #45419
by rellenberg
Replied by rellenberg on topic New Trajectory Planner - Testers/programs wanted
I've seen similar things when checking out the circular arc branch after building master. Try running make clean first and see if that helps.
- ldwilson46
12 years 7 months ago #45478
by ldwilson46
Bingo - make clean gave a happy compilation. Now on to checking it out. Thanks
-ldw
-ldw
Time to create page: 0.269 seconds
