- Thank you received: 4
That sounds nice and easy. Can you figure out the changes needed yourself?microsprintbuilder wrote: upon further review I've found that I have a input from the spindle drive that's called slow which pulls to ground when the spindle is slow enough to change gears so the timer is not needed but instead it needs to wait until the slow signal come true.
There are ways, but it might actually be easier to just move the PC nearer to the Internet for an evening.second item is I installed the dev package at the office and have to do a re install of the software at the shop and do not have internet there to just install off the internet. What is your suggestion on the best way to download the files and put them on a disc and install them that way? I know this is off topic but can the gscreen be installed offline as well? Thanks!
microsprintbuilder wrote: would I use a if statement or the spindle slow signal from the drive?
Also how would I handle the spindle values in the In file? they are different for each speed range.
