Electronic spindle gearbox
11 years 7 months ago #56573 by andypugh
Replied by andypugh on topic Electronic spindle gearbox
microsprintbuilder wrote: is the timeout = 10 ten seconds? or ten of something else?
"fperiod" is (floating point) seconds. "period" is nanoseconds.
www.linuxcnc.org/docs/html/hal/comp.html#_implicit_parameters
11 years 7 months ago #56709 by microsprintbuilder
does this look right?
component ebox "electronic gearbox component";
licence "GPL";
pin in bit spindle-slow
pin in bit spindle-on-in;
pin out bit spindle-on-out;
pin in float spindle-speed;
pin out bit relay1;
pin out bit relay2;
pin out bit relay3;
pin out s32 spindle-gearbox-output-scale
pin out s32 spindle-gearbox-out-min-limit
pin out s32 spindle-gearbox-out-max-limit
pin in s33 spindle-gearbox-low-output-scale
pin in s32 spindle-gearbox-low-min-limit
pin in s32 spindle-gearbox-low-max-limit
pin in s32 spindle-gearbox-mid-output-scale
pin in s32 spindle-gearbox-mid-min-limit
pin in s32 spindle-gearbox-mid-max-limit
pin in s32 spindle-gearbox-hi-output-scale
pin in s32 spindle-gearbox-hi-min-limit
pin in s32 spindle-gearbox-hi-max-limit
int gear-called
int gear-set
function _;
FUNCTION(_){
static int timer;
if (timer > 0){
timer -= 1;
spindle_on_out = 0;
} else {
spindle_on_out = spindle_on_in;
// determine gear required
if (spindle_speed >= 2500){
gear-called = 3
} else if (spindle-speed <= 1200)
gear-called = 1
} else
gear-called = 2
// determine if gear change required
while (gear-called <> gear-set)
spindle_on_out=0
if (spindle-slow=0){
wait
} else {
relay 1 = 0;
relay 2 = 0;
relay 3 = 1;
spindle-gearbox-output-scale = spindle-gearbox-hi-output-scale
spindle-gearbox-out-min-limit = spindle-gearbox-hi-min-limit
spindle-gearbox-out-max-limit = spindle-gearbox-hi-max-limit
gear-set = 3
timer = 2000
relay 1 = 1;
relay 2 = 0;
relay 3 = 0;
spindle-gearbox-output-scale = spindle-gearbox-low-output-scale
spindle-gearbox-out-min-limit = spindle-gearbox-low-min-limit
spindle-gearbox-out-max-limit = spindle-gearbox-low-max-limit
gear-set = 1
timer = 2000
} else {
relay 1 = 0;
relay 2 = 1;
relay 3 = 0;
spindle-gearbox-output-scale = spindle-gearbox-mid-output-scale
spindle-gearbox-out-min-limit = spindle-gearbox-mid-min-limit
spindle-gearbox-out-max-limit = spindle-gearbox-mid-max-limit
gear-set = 2
timer = 2000
11 years 7 months ago #56715 by andypugh
Rather than ask if it looks right, does it compile, and does it work?
11 years 7 months ago #56716 by microsprintbuilder
Haven't done that yet. I thought I'd ask to see if it's plausible. Instead I get my question answered with a question. Thanks for you help.
11 years 7 months ago #56717 by andypugh
It looks like it ought to work, except that you have relay 1 instead of relay1 (etc) in a few places. The pin names and variable names need to match exactly, and can't have spaces.
3 years 3 weeks ago #282515 by Trav328
Replied by Trav328 on topic Electronic spindle gearbox
Resurrected with mod approvalĀ
Microsprintbuilder , did you ever get this working right ? , I am doing a retrofit on a milltronics partner lathe with the identical spindle winding "gear" setup , probably even the same parts , im going to try compiling the last bit you posted and see what can be done with that , this board has no pm's so this is the only way to reach out.
Time to create page: 0.397 seconds
