Electronic spindle gearbox
12 years 3 months ago #48899 by microsprintbuilder
Sorry for the delay I've been gutting and installing the new PC and wiring the boards. I need to add that if you think you might hit the motherboard when drilling holes to mount the PC don't talk yourself out of removing it as I did or you will be replacing it. I'm hoping to get movement this weekend. I'm looking at this with a blank stare and have a few questions. I make a file with the above text in ( linuxcnc/src/hal/components ) and call it electronic gearbox. then in hal, I place loadrt electronic gearbox and then I define the relay 1,2 & 3 to my outputs?
12 years 3 months ago #48900 by andypugh
Replied by andypugh on topic Electronic spindle gearbox
microsprintbuilder wrote: I'm looking at this with a blank stare and have a few questions. I make a file with the above text in ( linuxcnc/src/hal/components ) and call it electronic gearbox. then in hal, I place loadrt electronic gearbox and then I define the relay 1,2 & 3 to my outputs?
Nearly. You would need to compile / install the new component using the "comp" tool.
www.linuxcnc.org/docs/html/hal/comp.html
Or, if you are using the development version, it has changed its name:
www.linuxcnc.org/docs/devel/html/hal/comp.html
12 years 3 months ago #48901 by microsprintbuilder
And this is done in a terminal window using sudo?
12 years 3 months ago #48903 by andypugh
You can use gedit to create and edit the file, but then, yes, "sudo comp --install ebox.comp
And then the hal file can contain "loadrt ebox"
12 years 3 months ago #48982 by microsprintbuilder
I cannot find the file linuxcnc/src/hal/components. Is it hidden. What is the first location? Home, documents, etc. ?
12 years 3 months ago #48983 by andypugh
microsprintbuilder wrote: I cannot find the file linuxcnc/src/hal/components.
Why are you looking for it? You can put ebox.comp anywhere convenient, and comp will compile it and move the executable file to the right place.
if
mentions programs like mm and mail then ignore it. You need to
sudo apt-get install linuxcnc-dev
Time to create page: 0.107 seconds
