Create variables in function of kinematics values
- jstoquica
- Thank you received: 9
24 Sep 2015 04:08 #62906
by jstoquica
Replied by jstoquica on topic Create variables in function of kinematics values
Something like that:
net J0pos irb.th1 irbgui.joint0
net J1pos irb.th2 irbgui.joint1
net J2pos irb.th3 irbgui.joint2
net J3pos irb.th4 irbgui.joint3
net J4pos irb.th5 irbgui.joint4
- Thank you received: 4995
24 Sep 2015 04:11 #62907
Replied by andypugh on topic Create variables in function of kinematics values
You will need new signal names, you can't use the same ones as you are already using for actuator positions.
- jstoquica
24 Sep 2015 04:37 #62909
by jstoquica
24 Sep 2015 04:45 #62910
Do you have the position-cmd to position-fb loopback in place for all active joints?
emc/task/taskintf.cc 614: Error on axis 3, command number 127
- jstoquica
24 Sep 2015 05:52 - 24 Sep 2015 05:52 #62914
by jstoquica
I enabled them, but the joints of vismach model doesn't move. Here is my HAL code:
# load RT modules
loadrt irb
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD traj_period_nsec=[EMCMOT]TRAJ_PERIOD num_joints=[TRAJ]AXES
#add motion controller functions to servo thread
# create HAL signals for position commands from motion module
net J0pos <= axis.0.motor-pos-cmd
net J1pos <= axis.1.motor-pos-cmd
net J2pos <= axis.2.motor-pos-cmd
net J3pos <= axis.3.motor-pos-cmd
net J4pos <= axis.4.motor-pos-cmd
# loop position commands back to motion module feedback
net J0pos => axis.0.motor-pos-fb
net J1pos => axis.1.motor-pos-fb
net J2pos => axis.2.motor-pos-fb
net J3pos => axis.3.motor-pos-fb
net J4pos => axis.4.motor-pos-fb
# estop loopback
net estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in
# create signals for tool loading loopback
net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
loadusr -W irbgui
net J0p irb.th1 irbgui.joint0
net J1p irb.th2 irbgui.joint1
net J2p irb.th3 irbgui.joint2
net J3p irb.th4 irbgui.joint3
net J4p irb.th5 irbgui.joint4
Last edit: 24 Sep 2015 05:52 by jstoquica.
24 Sep 2015 05:56 #62915
Are the th* pins changing value?
- jstoquica
24 Sep 2015 06:07 #62917
by jstoquica
They are not! With HAL meter I can check that the value is 0 for those pins.
24 Sep 2015 06:34 #62918
There is something wrong in your kinematics then.
Did you create the pins as output pins?
- jstoquica
24 Sep 2015 06:49 - 25 Sep 2015 03:18 #62919
by jstoquica
Yes, I did. I don't know what is wrong. I attach the kinematics file.
Thanks.
Thanks.
Last edit: 25 Sep 2015 03:18 by jstoquica.
24 Sep 2015 06:58 #62920
You might need to re-name it as a .txt file
I attach the kinematics file. .
Time to create page: 0.105 seconds
