Create variables in function of kinematics values
  • jstoquica
  • jstoquica's Avatar Topic Author
  • Premium Member
  • Premium Member
24 Sep 2015 07:02 - 25 Sep 2015 03:18 #62921 by jstoquica
Sorry, I had to restore the permissions.
Last edit: 25 Sep 2015 03:18 by jstoquica.
24 Sep 2015 07:19 #62925 by andypugh
It is possible that inverse kins doesn't run in joint mode (just a guess, I don't know for sure).
As a test, set the pins to 1, 2, 3, 4, 5 (for example) just before the function exit point.
  • jstoquica
  • Premium Member
  • Premium Member
24 Sep 2015 07:27 #62926 by jstoquica
like this ?
   /* Joint 5 */
   s5 = c1 * hom.rot.x.x + s1 * hom.rot.x.y;
   c5 = c1 * hom.rot.y.x + s1 * hom.rot.y.y;
   th5 = atan2(s5, c5);
   /* copy out */
   *(haldata->th1) = 2;//th1*180/PM_PI;
   *(haldata->th2) = 4;//th2*180/PM_PI;
   *(haldata->th3) = 6;//th3*180/PM_PI;
   *(haldata->th4) = 8;//th4*180/PM_PI;
   *(haldata->th5) = 10;//th5*180/PM_PI;
   joint[0] = *(haldata->th1);
   joint[1] = *(haldata->th2);
   joint[2] = *(haldata->th3);
   joint[3] = *(haldata->th4);
   joint[4] = *(haldata->th5);
   return 0;
  • jstoquica
  • Premium Member
  • Premium Member
24 Sep 2015 07:34 #62928 by jstoquica
I tested but the th? values are 0 yet.
24 Sep 2015 17:17 #62940 by andypugh
Making the change where you have will mess up the joint[] value outputs to axis.N.motor-position-cmd,
To check if the problem is that reverse kinematics doesn't run in joint mode, switch to world mode.
  • jstoquica
  • Premium Member
  • Premium Member
25 Sep 2015 03:28 #62955 by jstoquica
In fact, when is in "world mode" the thx values are the same that kinematics modified file. But the vismach model doesn't move.
25 Sep 2015 03:31 #62956 by andypugh
The model wouldn't move if the values are fixed to 1,2,3 etc.
What happens in world mode with the previous kinematics file?
  • jstoquica
  • Premium Member
  • Premium Member
25 Sep 2015 04:39 #62958 by jstoquica
After do that, the vismach model moved, but when run some G program the end-effector trajectory has X axis offset. Like can you see in the next image:
25 Sep 2015 05:11 #62959 by andypugh
How fascinating. Do let me know what the problem turns out to be :-)
  • jstoquica
  • Premium Member
  • Premium Member
25 Sep 2015 06:49 - 25 Sep 2015 06:56 #62962 by jstoquica
Yeah it's strange. However, I did the next:
1. Home all joints in "Joint Mode"
2. Switch to "World Mode"
3. Touch off all axis.
4. Run the program.
When I did that, the end-effector trajectory was success like you can see at image:
I have two questions:
1. I think isn't necessary, but, Is it possible works with the simulation and real operation in "Joint Mode"?
2. I still have not tried, but, are the position-cmd and position-fb loopback independents when I will simulate and control the motors, i.e., Can I control the virtual and real motors with them without any performance issue?
Thanks a lot for your time and knowledge.
Last edit: 25 Sep 2015 06:56 by jstoquica.
Time to create page: 0.111 seconds
