- Thank you received: 297
TCP 5-axis kinematics
- dgarrett
the motion module hal pin motion.switchkins-type
requires a user to:
Then the command to switch within gcode is:
In the provided sim configs:
So the switckins.ngc file is:
github.com/LinuxCNC/linuxcnc/blob/dgarr/...mples/switchkins.ngc
Other files in the same examples directory should work too:
github.com/LinuxCNC/linuxcnc/tree/dgarr/...ary-tilting/examples
Some may require touch off for Z, see:
github.com/LinuxCNC/linuxcnc/blob/dgarr/...otary-tilting/README
The sim configs gui includes buttons and
a label display to:
1) set to XYZAC (or XYZBC) via a halui mdi pin
or
2) set to trivkins via a halui mdi pin
3) Display the current active kins type
These may be useful for testing using jog
buttons (after homing of course)
- jsskangas
- Thank you received: 9
M66 a sync command? does some needed trick internally?
then switching a kinematics by hal pin with M68 command
and M66 again
Can we combine this all under one G or M code that is modal, like M128 what is user defined M command?
And M129 to deactivate it.
Would be easier from CAM/post point of view.
And NC-code would be more readable.
M128 is modal, so TCP active state is readable from active modal codes in UI.
- dgarrett
Yes - a workaround to allow changes to motion module to
be passed back to task. The synchronization is a
normal activity for commands that need to synchronize
task and interp. Such 'Queue-busting' commands
include probing, toolchange, and the reading of hal
inputs -- like M66.
1. A user is free to create user M codes to invoke the
setting of the motion.switchkins-type pin with code
like:
But, they are USER codes -- so you as a user
are free to add them but the base LinuxCNC code cannot
reserve the M number without potentially affecting
existing, unrelated configurations in the field.
(And, you would still need a command to sync.)
2. Perhaps a better alternative: as a user, you can
probably remap a command to subsume the
o<switchkins>call[mode] functionality for both setting
the hal pin and causing a sync. The remap docs
indicate that you can remap commands to a modal group.
See 'Section 2.4 Execution Sequencing' in:
Ref: linuxcnc.org/docs/master/html/remap/remap.html
I haven't tried it as i am not a user of remap.
My understanding is that with the current and
longstanding LinuxCNC code, the display of active codes
by a UI is *not* generally indicative of the
contemporaneous state of the motion module. Currently,
the state reported is based on the interpreter which
rapidly queues commands up until a queue buster. This
queueing is commonly completed well before motion acts
on commands so is not very useful while running. The
(stalled) state-tags branches intend to address that
issue in the future (see references at end of message).
The branch dgarr/s_kins intentionally avoids
modifications to the interpreter, task, and nml which
are needed for adding new gcodes. I avoided because:
1) Could not find a common/accepted/standard set of
gcode naming rules so the choice would just start a
debate and further delay implementation.
2) There are not many active developers that have
worked on the interpreter or task code in the last
several years to advise, help, or review code.
3) I do not have the experience or interest in the
wilderness of the interpreter and task modules to
want to undertake responsibilty for such code.
I think the dgarr/s_kins branch is workable and you may
be able to use remap to address your issues. If you
view your items as requirements it may be a long wait
for implementation.
links for statetags branches:
Ref: github.com/LinuxCNC/linuxcnc/commits/feature/state-tags-master
last touched August 2015
Ref: github.com/LinuxCNC/linuxcnc/commits/statetags
last touched Oct 2016
statetags issues:
Ref: github.com/LinuxCNC/linuxcnc/pull/283
Ref: github.com/LinuxCNC/linuxcnc/issues/134
- jsskangas
."A user is free to create user M codes to invoke the
like:
$ cat M128
#!/bin/bash
halcmd setp motion.switchkins-type 0 # trivins
exit 0
$ cat M129
#!/bin/bash
halcmd setp motion.switchkins-type 1 # xyzac,xyzbc
exit 0
Yes I'm already using this method, but can I include these Sync commands to it?
Or is it better to M128 to call subprogram that makes kin switch?
"1) Could not find a common/accepted/standard set of
debate and further delay implementation."
If I recall correct, TCP functionality is not included in ISO RS-274.
That is why TCP command varies between controllers.
Fanuc based controllers like: fanuc, mitsubishi, mazak, okuma, command is G43.4.
Siemens use TRAORI command to activate TCP.
Heidenhain native uses M128 to activate TCP.
I would not recommend to Fanuc way to use G43.4 for activating TCP.
Deactivating TCP in fanuc is done by G49 at the same time it will deactivate tool length compensation. I think you can go around this by commanding G43 again, this cancels TCP, but retains Toll length compensation on.
Currently we are doing it same way than Siemens or Heidenhain.
We have dedicated commands or in this case sub programs to turn on/off TCP(kinematics).
I think this is most best way.
- dgarrett
include these Sync commands to it? Or is it better to
A user mcode cannot call a gcode subroutine (the
interpreter is not reentrant) and currently there is no
way to request a synch except from gcode. However, I
could modify user m code handling so that a special
exit error code requests a synch. It is a signicant
change but could have some general utility so i will
investigate more.
A question regarding Heidenhain M128/129: What is the
default (startup) condition (M129==TCP_off or
M128==TCP_on)?
Eventually, i would *not* want to support redundant
code for kinematics (e.g., both
xyzac-trt-kins,xyzac-trt-switchkins) so we would have
only a single updated xyzac-trt-kins with switchable
enhancements (similarly for xyzbc).
Since there are existing users for xyzac-trt-kins,
for backwards compatibiliity, the startup (default)
kins type would need to be xyzac (e.g., TCP)
(If the TCP startup mode is mode is not wanted,
it could be addressed with a single halfile command
so i don't think it would be a show-stopper)
- 3D-Master
- Thank you received: 5
M128==TCP_on)?
I havent restarted a machine with TCP enabled yet but i believe that TCP off is the default.
