TCP 5-axis kinematics
6 years 11 months ago - 6 years 11 months ago #150437 by 3D-Master
Replied by 3D-Master on topic TCP 5-axis kinematics
The machines i refer to have Absolute Encoders (Hermle, DMG)
Because of the differing temperatures during the day the real center of rotation can move. Maybe on smaller machines it is not a problem :)
I have looked through the patch and found this:
+ loadusr -W xyzac-trt-gui
+ net :table-x joint.0.pos-fb xyzac-trt-gui.table-x
+ net :saddle-y joint.1.pos-fb xyzac-trt-gui.saddle-y
+ net :spindle-z joint.2.pos-fb xyzac-trt-gui.spindle-z
+ net :tilt-a joint.3.pos-fb xyzac-trt-gui.tilt-a
+ net :rotate-c joint.4.pos-fb xyzac-trt-gui.rotate-c
+ net :tool-offset motion.tooloffset.z
+ net :tool-offset xyzac-trt-kins.tool-offset xyzac-trt-gui.tool-offset
+ net :y-offset xyzac-trt-kins.y-offset xyzac-trt-gui.y-offset
+ net :z-offset xyzac-trt-kins.z-offset xyzac-trt-gui.z-offset
is this for the Vismach machine simulation?
What happens if you start the machine, home it, activate TCP, move all axes a small amount, then go in MDI, switch back to TrivKins and then command X0 Y0 Z0 A0 C0? thats when it says:
linear move on line 0 would exceed B´s negative limit
invalid params in linear command
that also happens if i write a program and then run it but does not happen when i have solely trivkins activated. Also why would i get an error for axis B if i dont even command axis B? I have to activate TCP again and then command XYZAC0, then i can deactivate TCP and i can move the axes via MDI or Program. i bet i did something wrong.
Last edit: 6 years 11 months ago by 3D-Master.
6 years 11 months ago #150448 by plopes9000
Replied by plopes9000 on topic TCP 5-axis kinematics
3D-Master wrote: The machines i refer to have Absolute Encoders (Hermle, DMG)
Did not consider thermal expansion.
3D-Master wrote: is this for the Vismach machine simulation?
Yes, and it did work for me.
3D-Master wrote: What happens if you start the machine, home it, activate TCP, move all axes a small amount, then go in MDI, switch back to TrivKins and then command X0 Y0 Z0 A0 C0? thats when it says:
Unfortunately at the moment my machine is disassembled .... I'm scraping it all, hence I cant really test it.
I agree that it's odd the message regarding B axis on a AC configured machine.
Since I can't test it now, I see only two ways forward, you reproduce it in the Vismach configuration and then I can test it as well, or you attach your config files and I have a look at it .... other ideas?
6 years 11 months ago #150449 by Leon82
Replied by Leon82 on topic TCP 5-axis kinematics
What kind of accuracy are you expecting to hold?
A machine like a yasda microcenter has linear motors and the casting, coolant, motors and oils are cooled via heat exchanger and cooling fluid.
To get the most accuracy you need to have it in a lab and hold the temperature within a fraction of a degree also.
Our matsuura mx , when we need to hold .02mm true position, it gets a separate work offset and we probe it prior to boring or machining.
6 years 11 months ago #150488 by 3D-Master
hopefully someday +-0.01mm but i probably wont if i dont find a (reasonably priced) incremental rotary encoder with 0,001° resolution for the rotary axes... and fix some errors :P
The following user(s) said Thank You: Leon82
6 years 11 months ago #150489 by 3D-Master
maybe if i replace all changed files with the original ones and then re-changing them to suit switchKins the error will be gone.
6 years 11 months ago #150781 by dgarrett
Replied by dgarrett on topic TCP 5-axis kinematics
I've created a branch to test/demonstrate kinematics
switching (xyzac & trivkins, xyzbc & trivkins).
The branch is based on the original work of Rudy du Preez
and subsequent modifications by Rushabh, JSKangas, Plopes
(and probably others). The branch supplies kinematics
modules (xyzac-trt-switchkins,xyzbc-trt-switchkins) and
modifies the motion module.
The branch incorporates a simplified approach that
avoids changes to the interpreter, task, and nml.
Kinematics switching uses a new hal pin and existing
interpreter synching commands.
Summary:
1) A new hal pin (motion.switchkins-type) instructs a
candidate kinematics module to switch to a specified
kinematics type.
2) A gcode subroutine (switchkins.ngc) sets a motion analog
output pin netted to motion.switchkins-type and issues M66
(wait-on-input) commands to synchronize task and motion.
Since the code changes are limited to the motion module,
this branch presents a low risk for incorporation into the
master branch (if it survives user testing).
The branch is on github as dgarr/s_kins and includes
sim configs:
configs/sim/axis/vismach/5axis/table-rotating-tilting/xyzac-trt-switchkins.ini
configs/sim/axis/vismach/5axis/table-rotating-tilting/xyzbc-trt-switchkins.ini
Many aspects can be tested with the sim configs but
I lack equipment to do hardware tests. Interested
users are encouraged to respond to this thread with
testing results (or email me d g a r r e t t at panix dot com)
Ref: github.com/LinuxCNC/linuxcnc/commits/dgarr/s_kins
The following user(s) said Thank You: tommylight, plopes9000
Time to create page: 0.168 seconds
