- Thank you received: 5
TCP 5-axis kinematics
- 3D-Master
did you do exactly the below again for the master branch dir?
yes i did copy and paste.
i just did it again. what i am wondering is, why is it reading 0/206 realtime dependencies?
the start of "make":
stevie@stevie:~/linuxcnc-master-branch/src$ make
Reading 191/191 dependency files
Done reading dependencies
Reading 0/206 realtime dependency files
Done reading realtime dependencies
Compiling hal/user_comps/mb2hal/mb2hal.c
Compiling hal/user_comps/mb2hal/mb2hal_init.c
Compiling hal/user_comps/mb2hal/mb2hal_modbus.c
Compiling hal/user_comps/mb2hal/mb2hal_hal.c
Linking mb2hal
Compiling hal/classicladder/arithm_eval.c
Compiling hal/utils/scope_disp.c
Compiling hal/utils/scope_files.c
Linking halscope
Compiling emc/usr_intf/axis/extensions/emcmodule.cc
Linking python module linuxcnc.so
Linking ../rtlib/abs.so
ld: no input files
Makefile:1051: die Regel für Ziel „../rtlib/abs.so“ scheiterte
make: *** [../rtlib/abs.so] Fehler 1
this is where it stopps.
- plopes9000
- Thank you received: 18
I think Andy can help here better than I ....
- plopes9000
make clean
make -j2
the second line output should look like this:
- 3D-Master
try this :
make clean
make -j2
that worked, runtests worked as well.
should i do the same for the linuxcnc-switchkins folder?
- plopes9000
You would now need to apply the changes of switchkins to the master branch code.
when done, just go back to ~/linuxcnc-master-branch/src and issue "make -j2".
"-j2" is just to speed it up ....
- Leon82
- Thank you received: 79
plopes9000 wrote: You could but the idea is to get the master branch with the switchkins code, hence no point.
Back when I compiled Android I always did - j16.
They said use double your CPU cores
