TCP 5-axis kinematics
6 years 11 months ago #149535 by 3D-Master
Replied by 3D-Master on topic TCP 5-axis kinematics
thanks, i will have a look later
6 years 11 months ago - 6 years 10 months ago #149538 by plopes9000
Replied by plopes9000 on topic TCP 5-axis kinematics
Here is the patch that contains the changes I am using. includes switchkins, TCP based on orig and no position reset when homing on index.
[NEW]
I just blindly tar'ed all changed files
git diff --name-only master pl-switchkins | xargs tar -cf pl-switchkins.tar
Last edit: 6 years 10 months ago by plopes9000.
6 years 11 months ago #149539 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
3D-Master wrote: so i successfully switched from 2.7.14 to 2.8 but now my servos create a biig following error because they somehow turn really sluggish. Is that correct? has there been some changes to how linuxcnc drives servos?
No, that certainly is not correct.
I would suggest that you compare the new and old HAL files to see if the conversion has messed up the bit that sets the PID gains.
The other possible source of this problem is in the FF0 / FF1 / FF2 connections.
6 years 11 months ago #149657 by 3D-Master
i am stuck at
./configure --with-realtime=uspace
it says:
Makefile:84: Makefile.inc: Datei oder Verzeichnis nicht gefunden
Makefile:95: *** Makefile.inc must specify RTPREFIX and other variables.
in ~/linuxcnc-master-branch/src i can see a file called "makefile.inc.in" and just "Makefile"
6 years 11 months ago #149726 by andypugh
Did you run ./autogen.sh ? And did that work?
(You probably need to install auto-tools)
6 years 11 months ago #149947 by 3D-Master
autotools were installed.
i needed to install some extra files and libraries and now it "makes" but then i get an error:
Linking halscope
Compiling emc/usr_intf/axis/extensions/emcmodule.cc
Linking python module linuxcnc.so
Linking ../rtlib/abs.so
ld: no input files
Makefile:1051: die Regel für Ziel „../rtlib/abs.so“ scheiterte
make: *** [../rtlib/abs.so] Fehler 1
stevie@stevie:~/linuxcnc-master-branch/src$
i have searched but havent found a solution :/
Time to create page: 0.255 seconds
