TCP 5-axis kinematics
7 years 2 months ago - 7 years 2 months ago #143590 by plopes9000
Replied by plopes9000 on topic TCP 5-axis kinematics
jsskangas wrote: Hello
Page 4
file is rotate.ngc
Yes totally missed it. Its a different approach. With the Haas like DWO, one rotates at will and then calls the DWO activation.
Last edit: 7 years 2 months ago by plopes9000.
7 years 1 week ago #148482 by plopes9000
Got myself into scraping the mill ways ... this is going to take a while, hence no updates on the 5 axis for now.
Been on my mind for a while and now with the 5 axis really want to have a precise and smooth machine.
Scraping a single surface or a square is pretty easy, specially power scraping, scraping ways and dove tails is quite a bit trickier ... I think on a good way now - it’s been at least 3 weeks since I started.
Have also considered linear guides but putting it off for now.
Anyone else has updates?
Cheers,
Paulo
6 years 11 months ago #149446 by 3D-Master
Replied by 3D-Master on topic TCP 5-axis kinematics
how do i get the G12.1 command? I have switched to 2.8 (pre something something) and compiled the switchKins.c and i can start the config but it doesnt recognize G12.1 P1/P0
6 years 11 months ago - 6 years 11 months ago #149451 by plopes9000
3D-Master wrote: how do i get the G12.1 command? I have switched to 2.8 (pre something something) and compiled the switchKins.c and i can start the config but it doesnt recognize G12.1 P1/P0
You will need to retrofit the "switchkins" branch github.com/rushabhGH/linuxcnc/tree/switchKins to your local code, all changed files.
12.1 is defined here:
13 src/emc/rs274ngc/interp_check.cc @@ -109,6 +109,11 @@ int Interp::check_g_codes(block_pointer block, //!< pointer to a block to be c NCE_CANNOT_USE_G53_INCREMENTAL); } else if (mode0 == G_92) { } else if ((mode0 == G_92_1) || (mode0 == G_92_2) || (mode0 == G_92_3)) { } else if (mode0 == G_12_1) { // kins-switch CHKS((block->p_number == -1), NCE_P_WORD_MISSING_WITH_G121); // CHKS((block->q_number == -1), NCE_Q_WORD_MISSING_WITH_G121); } else ERS(NCE_BUG_BAD_G_CODE_MODAL_GROUP_0); return INTERP_OK; @@ -311,7 +316,7 @@ int Interp::check_other_codes(block_pointer block) //!< pointer to a block }
Last edit: 6 years 11 months ago by plopes9000.
The following user(s) said Thank You: 3D-Master
6 years 11 months ago #149490 by 3D-Master
so i successfully switched from 2.7.14 to 2.8 but now my servos create a biig following error because they somehow turn really sluggish. Is that correct? has there been some changes to how linuxcnc drives servos?
6 years 11 months ago #149492 by plopes9000
3D-Master wrote: so i successfully switched from 2.7.14 to 2.8 but now my servos create a biig following error because they somehow turn really sluggish. Is that correct? has there been some changes to how linuxcnc drives servos?
I’m using 2.9pre, can’t say I saw any change with regards to that. I use the Mesa 7i76 for step generation only.
Maybe someone else can comment on that behavior for 2.8.
Time to create page: 0.450 seconds
