- Thank you received: 3
Servo Wiring and Tuning detailed How To example Mesa 7i77.
- tommy
1 year 7 months ago #324913
by tommy
Replied by tommy on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
Yes, it is step/dir driver.
If it helps, here are .ini and .hal sections, related to this axis:
[AXIS_X]
MIN_LIMIT = -1
MAX_LIMIT = 1100
MAX_VELOCITY = 170
MAX_ACCELERATION = 200
[JOINT_0]
CARD = 0
TAB = 0
AXIS = X
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 170
#PID_MAX_VEL = 10
BACKLASH = 0.000
STEP_INVERT = False
DIR_INVERT = False
STEPGEN_MAX_VEL = 220
STEPGEN_MAX_ACC = 250
DIRSETUP = 200
DIRHOLD = 200
STEPLEN = 800
STEPSPACE = 800
SCALE = -1998.6
ENCODER_SCALE = -1998.6
MIN_LIMIT = -1.0
MAX_LIMIT = 1100
FERROR = 10
MIN_FERROR = 7
HOME_OFFSET = -4.0
HOME_SEARCH_VEL = -10
HOME_LATCH_VEL = 2
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
DEADBAND = 0.001
P = 100
I = 0
D = 15
BIAS = 0
FF0 = 0
FF1 = 1
FF2 = 0.01
MAX_OUTPUT = 0
# PID Setup
setp pid.x.Pgain [JOINT_0](P)
setp pid.x.Igain [JOINT_0](I)
setp pid.x.Dgain [JOINT_0](D)
setp pid.x.bias [JOINT_0](BIAS)
setp pid.x.FF0 [JOINT_0](FF0)
setp pid.x.FF1 [JOINT_0](FF1)
setp pid.x.FF2 [JOINT_0](FF2)
setp pid.x.deadband [JOINT_0](DEADBAND)
setp pid.x.maxoutput [JOINT_0](MAX_OUTPUT)
#setp pid.x.error-previous-target True
# limit stepgen velocity corrections caused by position feedback jitter
#setp pid.x.maxerror [JOINT_0](MAX_ERROR)
# joint-0 enable chain
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-output => pid.x.output
net x-pos-cmd => pid.x.command
net x-vel-fb => pid.x.feedback-deriv
net x-pos-fb => pid.x.feedback
# Joint 0 Step Gen signals/setup
setp hm2_[MESA](BOARD).0.stepgen.00.dirsetup [JOINT_0](DIRSETUP)
setp hm2_[MESA](BOARD).0.stepgen.00.dirhold [JOINT_0](DIRHOLD)
setp hm2_[MESA](BOARD).0.stepgen.00.steplen [JOINT_0](STEPLEN)
setp hm2_[MESA](BOARD).0.stepgen.00.stepspace [JOINT_0](STEPSPACE)
setp hm2_[MESA](BOARD).0.stepgen.00.position-scale [JOINT_0](SCALE)
setp hm2_[MESA](BOARD).0.stepgen.00.maxvel [JOINT_0](STEPGEN_MAX_VEL)
setp hm2_[MESA](BOARD).0.stepgen.00.maxaccel [JOINT_0](STEPGEN_MAX_ACC)
setp hm2_[MESA](BOARD).0.stepgen.00.step_type 0
setp hm2_[MESA](BOARD).0.stepgen.00.control-type 1
# ---closedloop stepper signals---
net x-pos-cmd joint.0.motor-pos-cmd
net x-output => hm2_[MESA](BOARD).0.stepgen.00.velocity-cmd
net x-enable joint.0.amp-enable-out => hm2_[MESA](BOARD).0.stepgen.00.enable
setp hm2_[MESA](BOARD).0.encoder.00.counter-mode 0
setp hm2_[MESA](BOARD).0.encoder.00.filter 1
setp hm2_[MESA](BOARD).0.encoder.00.index-invert 0
setp hm2_[MESA](BOARD).0.encoder.00.index-mask 0
setp hm2_[MESA](BOARD).0.encoder.00.index-mask-invert 0
setp hm2_[MESA](BOARD).0.encoder.00.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= hm2_[MESA](BOARD).0.encoder.00.position
net x-vel-fb <= hm2_[MESA](BOARD).0.encoder.00.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_[MESA](BOARD).0.encoder.00.index-enable
net joint-0-pos-rawcounts <= hm2_[MESA](BOARD).0.encoder.00.rawcounts
- tommy
1 year 7 months ago #324992
by tommy
The following user(s) said Thank You: tommylight, ktm950adv
- besriworld
- Thank you received: 92
8 months 3 weeks ago #342688
by besriworld
Replied by besriworld on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
I am trying to configure the spindle as a C-axis, but I am having a problem and cannot find a solution.
Could someone please take a look at my configuration and the video and give me some advice?
I was not able to post this in the original lathe thread.
# AXIS C JOINT 2
setp pid.c.Pgain [JOINT_2](P)
setp pid.c.Igain [JOINT_2](I)
setp pid.c.Dgain [JOINT_2](D)
setp pid.c.bias [JOINT_2](BIAS)
setp pid.c.FF0 [JOINT_2](FF0)
setp pid.c.FF1 [JOINT_2](FF1)
setp pid.c.FF2 [JOINT_2](FF2)
setp pid.c.deadband [JOINT_2](DEADBAND)
setp pid.c.maxoutput [JOINT_2](MAX_OUTPUT)
setp pid.c.error-previous-target true
net c-index-enable => pid.c.index-enable
net c-enable => pid.c.enable
net c-pos-cmd => pid.c.command
net c-spindle-pos-fb => pid.c.feedback
net c-output <= pid.c.output
# ---PWM Generator signals/setup---
268 net c-output => hm2_7i98.0.pwmgen.00.value
269 net c-pos-cmd <= joint.2.motor-pos-cmd
270 net c-enable <= joint.2.amp-enable-out
271 # enable _all_ sserial pwmgens
272 #net c-enable => hm2_7i92.0.7i77.0.1.analogen
276 net c-spindle-pos-fb <= hm2_7i98.0.encoder.02.position
277 net c-spindle-vel-fb <= hm2_7i98.0.encoder.02.velocity
278 net c-spindle-pos-fb => joint.2.motor-pos-fb
279 #net c-index-enable joint.0.index-enable <=> hm2_7i92.0.encoder.06.index-enable
280 net c-pos-rawcounts <= hm2_7i98.0.encoder.02.rawcounts
282 # ---setup home / limit switch signals---
284 net c-home-sw => joint.2.home-sw-in
285 net c-neg-limit => joint.2.neg-lim-sw-in
286 net c-pos-limit => joint.2.pos-lim-sw-in
[AXIS_C]
MAX_VELOCITY = 360
MAX_ACCELERATION = 500
MIN_LIMIT = -900.0
MAX_LIMIT = 900.0
[JOINT_2]
TYPE = ANGULAR
HOME = 0.0
FERROR = 1000.0
MIN_FERROR = 500.0
MAX_VELOCITY = 360
P = 0.0000001
I = 0.
D = 0.
FF0 = 0.98
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0.1
MAX_OUTPUT = 10
ENCODER_SCALE = -40
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -1000
MAX_LIMIT = 1000
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
# AXIS C JOINT 2
[AXIS_C]
MAX_VELOCITY = 360
MIN_LIMIT = -900.0
MAX_LIMIT = 900.0
[JOINT_2]
TYPE = ANGULAR
HOME = 0.0
FERROR = 1000.0
MIN_FERROR = 500.0
MAX_VELOCITY = 360
P = 0.0000001
I = 0.
D = 0.
FF0 = 0.98
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0.1
MAX_OUTPUT = 10
ENCODER_SCALE = -40
OUTPUT_SCALE = 10
MIN_LIMIT = -1000
MAX_LIMIT = 1000
HOME_OFFSET = 0.0
HOME_SEQUENCE = 1
- Thank you received: 7491
8 months 3 weeks ago #342689
Replied by tommylight on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
Why?P = 0.0000001
I = 0.
D = 0.
- besriworld
8 months 3 weeks ago - 8 months 3 weeks ago #342693
by besriworld
If you have time, please watch the video.
Even with a very small P value, the axis starts to oscillate.
PS. I understand that Linuxcnc is fighting with the internal PID controller of the servo driver.
Last edit: 8 months 3 weeks ago by besriworld.
8 months 3 weeks ago #342711
Remove the dots after the 0 for I and D.
From video, definitely something wrong, but no idea what, that is not normal oscillation as it is moving way to much back and forth.
Do some plots using halscope for command and f-error
Time to create page: 0.157 seconds
