Servo Wiring and Tuning detailed How To example Mesa 7i77.
09 Feb 2026 18:16 #342721 by PCW
What is the PID output controlling, torque or velocity?
From the video it looks like you are controlling torque, in which case
you either need cascaded PID loops (inner  velocity --> torque and
outer position --> velocity loops) or a single loop with a large amount of D term
I would first  try adding D term to your existing setup. the more D term you add,
the more P term will be stable.
A torque loop --> position loop with no D term, that is, the restoring force
is only proportional to displacement  is  basically a pendulum...
The following user(s) said Thank You: tommylight, besriworld
Time to create page: 0.159 seconds
