Servo Wiring and Tuning detailed How To example Mesa 7i77.
7 years 2 months ago #141530 by Type_Zero_Design
Replied by Type_Zero_Design on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
Thanks Todd,
I will check that out when I get back to the garage. It is completely possible that I mis-remember the fact that the DRO was reading with manual rotation.
7 years 2 months ago #141559 by Type_Zero_Design
Tommy,
I just got a chance to take a look at this. So you were correct it is not counting on the DRO when moved by hand... I can go into Hal config and look at the encoder count under: pins/hm2_7i76e/0/encoder
That shows the the encoder counting.
So what's the Disconnect here and how do I resolve?
7 years 2 months ago #141560 by HueyHQ
Type_Zero_Design wrote: Lastly, will my accel/decell and velocity affect the tune. Should they be solidified prior to running? I'm not to sure on how to decide those numbers yet.
Just to add my experience about tuning with regards to acceleration values!
On my retrofit, I had a lot of trouble tuning following all the advice I had found because I had entered an arbitrary value for the acceleration parameter (way too high). It wasn't until I bumped it down to something more in line with what I had seen in others config files, that I could even start to tune my servos. My machine works fine now, but doesn't move as fast as it did before the retrofit, so I could go back and refine the tuning with higher accel params.
So, yes - in my experience, acceleration values will affect the tune!
The following user(s) said Thank You: tommylight, suraj9735
7 years 2 months ago #141596 by tommylight
@Type 0
You are better of by doing a new config than chasing gremlins at this stage.
You can post the config files here, you might have already but am on the phone so not much use for now from me.
I'll have a look when i get my hands on one of my laptops.
Regards,
Tom.
The following user(s) said Thank You: Type_Zero_Design
7 years 2 months ago #141597 by tommylight
@Huey
Thank you, i missed answering that.
7 years 2 months ago #141626 by Type_Zero_Design
So Tommy, is there something I need to do different in setting up the config this go round to make sure that happens? is there some option I need to enable in PNCConfig?
Time to create page: 0.143 seconds
