how to synchronize two servomotors
9 years 3 months ago #95329 by Todd Zuercher
Are you 100% sure all of your motor and drive connections are correct? Nothing is crossed, So that Linuxcnc Y1 command signals and encoder feed back are connected to the drive for Y1 and that is connected to the motor power and encoders for the Y1 motor. And the same for Y2, If any of those things are confused between Y1 and Y2, wildly disastrous things could happen, and tuning would be impossible. (This really does kind of sound to me like one of the command signals or encoder feedback signals might be crossed between Y1 and Y2.)
You should be able to run the Y1 and Y2 open loop, using the PID. You simply don't connect the encoder feedbacks to the PID loop feedbacks. Instead connect the PID feedbacks to the sudo feedbacks from the hardware stepgenerators. (using P=1000 and FF1=1 (all other PID settings set to 0). If you can get that to work. Then you could try reconnecting only one of the encoder feedbacks and tuining only that one side. If you can get that to work acceptibly, then you could try adding the feedback from the 2nd motor.
9 years 3 months ago #95330 by Jasper 3
hey,
when the motors are both connectet without timingbelt they defenetly work against each other.
only in openloop when they are connectet via belt it could be possible. I will test it tomorrow.
Do you mean there is a possibility to get it working?
9 years 3 months ago #95366 by Jasper 3
hey
today I tried a lot but unfortunally nothing worked. Before I can try your suggestion Todd I have to tune my Driver with the leadshine software.
After I run Linuxcnc a while I get this message. Than I restart linuxcnc and everything is great again. Any suggestions what I can do?
9 years 3 months ago #95367 by PCW
Look like you have lost communication with the 7I76 card
The combination of joint following errors and sserial errors suggests there may
be a problem with 7I76s 5V since that affects step/dir outputs and sserial communications
9 years 3 months ago #95368 by andypugh
Which version of LinuxCNC?
Does dmesg give you a Smart Serial version number?
9 years 3 months ago #95379 by Jasper 3
I power the 7i76 via FPGA card. so you suggest to connect an external voltage?
I run the 2.8 prerealese but also had this problem under version 2.7.8
I'm not sure what you mean "Does dmesg give you a Smart Serial version number?" can you tell me where I have to look at?
Time to create page: 0.502 seconds
