Hey,
ok I will try this Master branch, when I have again Internet on my Linux CNC computer.
Today I've tried to Tune my Servo-drives via Linux CNC.
So If I use the Ecoderfeedback to close the loop I always get following erros when I accelerate to fast. I also tuned PID and FF1 to reasonable values. But the max velocity is only 1000mm/min. In an open Loop system I can run 15 000 mm/min without problems.
The reason for this slow travel speed is in my opinion the encoder feedback which causes a f-error. I think the motor can't accelerate as fast as needed. But reducing the acceleration means that the axis only reached a maximum velocity of maybe 3000mm/min. (The axis travel is only 400mm.
The Probelm is that I need to close the Loop with LinuxCNC to synchronize my Axis.
I hope you can help me accelerate much faster in the closed loop system.
Here to pictures of the tuning of my X-Axis
