Hardinge Super slant 3 axis
- robh
- Thank you received: 24
30 Sep 2018 03:46 #118228
by robh
Replied by robh on topic Hardinge Super slant 3 axis
if you look over this forum you should find all my info on doing a superslant machine with config files i am sure also.
there is aload of youtube vids i did too of the machien running.
afew things you have to live with display wise etc...
thankfully now days we have all 5 axis tool offsets UVW .. so big thanks to the devs there..
when i started there where none as it had to be a Y axis.. which made things a big pain.. W is so much better.
you will have to ignore the back plot unless you do as andy said turn of the W on the display, its only drilling anyways so not like you need to check back plot for it
i do have a 4 axis power tooled version of this machine to refit some time.. good luck on the refit
- Deckerjwd
- Thank you received: 3
06 Oct 2018 08:52 #118492
by Deckerjwd
Replied by Deckerjwd on topic Hardinge Super slant 3 axis
how did you handle the second turret?
Time to create page: 0.568 seconds
