Bipod setup
13 Aug 2010 12:54 #3729 by dab77
Replied by dab77 on topic Re:Bipod setup
by now i'm ok for this bipod.. i'm going to study it more when i'll add a joystick to control.
now, i'm trying tripod kinematics, so i'm going to start a new thread.
thank andypugh for useful helping.
wish you'll help me the same with tripod!!
ciao!:)
25 Aug 2010 12:40 #3869 by benehuber
Replied by benehuber on topic Re:Bipod setup
step4linux wrote:
hi dab,
I did a dualbipod, and started like you did with trivkins.
You can find it here code.google.com/p/emc2hotwinch/ .
Hi Gerd,
I need your help, I used your configuration emc2hotwinch with emc under ubuntu 8.04. now I installed 10.04 with emc 2.4.3 and habe problems with dualpipod. Can you help me with rtai realtime-2.6.32-122-rtai?
I think I need dualpipod for mentioned Kernel or?
thx
bene
25 Aug 2010 13:08 #3871 by andypugh
Replied by andypugh on topic Re:Bipod setup
Do you still have the original kinematics module source code (probably dualbipod.c).
If so then you should be able to compile and install that into your new system.
sudo apt-get install emc2-dev
comp --install dualbipod.c
Should do the trick. (or some variant of that with the correct paths)
25 Aug 2010 18:32 #3873 by benehuber
thank you for your answer. I found the kins on the emc2hotwinch side.
I'll try it during next days.
Thank you
26 Aug 2010 06:19 #3876 by benehuber
I tried the solution but without luck.
make -C /usr/src/linux-headers-2.6.24-16-rtai SUBDIRS=`pwd` CC=gcc V=0 -o /Module.symvers modules
make: *** /usr/src/linux-headers-2.6.24-16-rtai: No such file or directory. Schluss.
make: *** [modules] Fehler 2
in file /etc/emc2/Makefile.modinc are all path with 2.6.24-16 kernel!
when i change these paths I got another error.
next steps ;)
26 Aug 2010 11:19 #3879 by andypugh
Are you using "comp" or "make"?
26 Aug 2010 14:27 #3884 by benehuber
comp
as you wrote
26 Aug 2010 17:35 #3889 by koppi
Replied by koppi on topic Re:Bipod setup
You can try my code from this website: goo.gl/ixul I cant remember, howto compile the stuff, but in the end, it worked all fine: goo.gl/Pvbp
Kind regards,
Jakob
27 Aug 2010 09:43 #3899 by andypugh
Comp probably needs header files from the source tree to compile the kinematics module.
There are various ways to get the source, but this is as good as any:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?git
31 Aug 2010 15:49 - 31 Aug 2010 15:50 #3928 by step4linux
Replied by step4linux on topic Re:Bipod setup
hi Bene,
Do you successfully run 2.4.3 on 10.04 ? including Axis ?
I tried but there are still problems.
Also the dualbipod.c is not able to compile on 2.4.3. It seems there are some changes in the code structure of EMC.
I had no time for investigations up to now, please be patient (or try by yourself and let me know the result ;) )
regards, Gerd
Last edit: 31 Aug 2010 15:50 by step4linux.
