Bipod setup
27 Sep 2010 14:41 #4367 by Schnitti
Replied by Schnitti on topic Re:Updating
Built-in Ubuntu Updater.
27 Sep 2010 15:06 #4370 by andypugh
Replied by andypugh on topic Re:Updating
That will break EMC2.
EMC2 relies on a patched, custom, kernel which handles the real-time stuff. A standard Ubuntu installation will install the default Ubuntu kernel for 10.04.
I _think_ that you can install from the LiveCD without overwriting everything on the HD. (downloadable from the link on the left)
27 Sep 2010 18:35 #4375 by Schnitti
Using built-in Updater is very useful, if you do it right.
The update-manager (UM) will deactivate all third party repos, like emc2 in its first run. UM will aks you, if it should do so. Accept YES, because aptitude thinks, that emc2 is out of date (no repos) it will completely remove emc2. Then you get a Ubuntu 10.04 without RTAI. Then add EMC2 to the repos back again. Update and install emc2. linux-image-2.6.32-rtai-122 will install. Boot with rtai. remove generic image. Done.
What is the difference to overwriting?
No problem, if you make it right. It will not break, but you must know what you are doing.
I gave it a chance in a virtualbox environment and it was a better update than ever. Believe me.
Regards
Wolfgang
28 Sep 2010 05:31 #4380 by step4linux
Replied by step4linux on topic Re:Bipod setup x and y wrong
andypugh wrote:
In a trivial kinematics machine (cartesian joints and cartesian axes) you would just change the mapping between motors/joints and axis positions commands in HAL.
With the bipod, however, you will probably need to alter the kinematics source-code. (exchange pos->tran.x with pos->tran.y throughout)
It seems odd that you would have this problem, however, if other people have not.
It's just a matter of definition.
The bipod code is based on the definition, that the x axis is parallel to the straight line between both bipod reference points. This is of course arbitrary. But I think Andy is right: the only way to change it, is to change the c-code.
Gerd
28 Sep 2010 08:42 #4381 by Schnitti
Replied by Schnitti on topic Re:Bipod setup x and y wrong
Hi Gerd, Andy,
it is a question of winding the ropes. CW and CCW are not the same. :(
And I set up with the wrong stepping parameteres not suitable to the driver. My mistake.:woohoo:
To make shure, it is correctly winded:
Let the ropes hang free and unwinded! Then pull them up with + in emc2 to ensure the correct direction of winding. Then go to world mode.
Part 2:
Does anyone care about the correction of COMP and its Makefile template? Should be done, so that inexperienced users can build modules on their own.
Wolfgang
28 Sep 2010 09:29 #4382 by andypugh
Replied by andypugh on topic Re:Bipod setup x and y wrong
I meant to check whether it is a problem on all installations.
Things get rather lost here on the forum, as the developers tend to concentrate on the mailing list and IRC. You could try submitting a bug report via sourceforge:
sourceforge.net/tracker/?atid=106744&group_id=6744&func=browse
28 Sep 2010 09:58 #4383 by BigJohnT
Replied by BigJohnT on topic Re:Bipod setup x and y wrong
Schnitti wrote:
Hi Gerd, Andy,
Part 2:
Wolfgang
There seems to be nothing wrong with COMP in a proper install of EMC2.
28 Sep 2010 11:35 #4386 by step4linux
Not sure about that. As far as I remember there was a problem with a missing header file in my 1st 2.4 installation.
Unfortunately I am under water with my professsion ATM, so I could not care about it.
Could be with an official version, it is fixed.
I will check as soon as I have time.
Gerd
28 Sep 2010 13:07 #4388 by Schnitti
Hi Gerd,
thanks. Would be interesting, whether comp works for you on your machine. PM follows.
I have filed a bug report about that with my sf user. Hopefully correct assigned.
I am going to buy some styro to make a real test with this work.
Regards
Wolfgang
28 Sep 2010 16:37 #4392 by step4linux
I made a quick test with my fresh 10.04/2.4.4 system.
I still have this error:
/tmp/tmpV8rQEs/dualbipod.c:175: error: ‘HAL_SUCCESS’ undeclared (first use in this function)
This symbol was in 8.04 in a header file, now its missing or moved.
There is another thing, I found by chance:
If the path name where your files are located contains blanks, there are additional "no such file" errors.
Wolfgang, make sure your work path does not contain any blank or other special characters.
Gerd
Time to create page: 0.221 seconds
