- Thank you received: 11
That is much, much better.barisduzenli wrote: Hello Tommy,
Yes I am using a PCI Wifi Adapter. I plug out it and I am scaned bios settings I closed almost everything except usb and Lan adapter.
And YES. I get Servo Thread Max Jitter is aroud 38800 and Base Thread Max jitter is around 42700.
Savaal, teshekyr, abey !
Was that correct ?
No. But when you say abey! We are laughing loudly in office. Now we are calling each other as abeyyy!!
Sockheaven wrote: For multicore machines I have found big benefits in isolating the last cpu core for realtime events.
Look into ISOLCPUS for the realtime kernel.
at the command line run:
$ sudo nano /etc/default/grub
Find the line GRUB_CMDLINE_LINUX="" and update it to:
GRUB_CMDLINE_LINUX="isolcpus=1" (where 1 is the highest CPU core, dual core = 1, quad core = 3, etc)
then run:
$ sudo update-grub
and reboot, your RT jitter times should decrease
Nice !barisduzenli wrote: But when you say abey! We are laughing loudly in office. Now we are calling each other as abeyyy!!
