- Thank you received: 5334
Format and type of data passed to Mesa Control Card from LCNC?
3 years 7 months ago - 3 years 7 months ago #266716
Replied by PCW on topic Format and type of data passed to Mesa Control Card from LCNC?
I don't know if Torstep uses LBP16 or not...
You would probably have to look at the driver source to find out.
Last edit: 3 years 7 months ago by PCW.
The following user(s) said Thank You: Cyber
- rene-dev
- Thank you received: 27
3 years 7 months ago #266922
by rene-dev
Replied by rene-dev on topic Format and type of data passed to Mesa Control Card from LCNC?
controlling the card directly from ros is a bad idea. ros is not realtime capable, and has no concept of safety. Instead I reccomend using a hal ros bridge:
github.com/tormach/hal_ros_control
this allows you to use any hardware with a hal driver, like mesa or ethercat. And you can implement additional logic in hal, that is executed independent of ros.
The following user(s) said Thank You: DPFlex
- rene-dev
3 years 7 months ago #266924
by rene-dev
the torstep board uses the normal hostmot2 driver.
- Cyber
3 years 7 months ago #267164
by Cyber
Replied by Cyber on topic Format and type of data passed to Mesa Control Card from LCNC?
Thank you for replying, do you know if there is any lbp16 decoder? I need to understand the data that is transferred between the PathPilot controller and the xsTech router. I used the Wireshark to capture the packets.
- rene-dev
3 years 7 months ago #267165
by rene-dev
Like I said, it uses the hm2_eth driver(just like mesa cards), which you can find in the linuxcnc src. you will not be able to control it form ros, as realtime is required.
- Cyber
3 years 7 months ago #267166
by Cyber
thank you for the response, I'm not trying to control the card I'm trying to understand the communication between the controller and the card for a research purposes. I'm doing a research in PP and CNC machines. Do you have any idea how can I get more knowledge about the data been transferred among the communication?
Time to create page: 0.414 seconds
