lathe with 3 stepper one for each axis Solved
- alejandrolleida
07 Mar 2020 01:41 - 30 Aug 2020 02:27 #159364
by alejandrolleida
lathe with 3 stepper one for each axis Solved was created by alejandrolleida
hi frends
I have built a lathe with 3 axis as usual but the axis are moved with 3 steppers, first attempt was with grbl ant that doesn't work maybe i need to reprogram but i can't program this is so difficult for me and now I'm trying to configure with linux cnc but in the manual lathes are sincronized with encoder i wish to configure with steppers.
Is it possible?
How can I do it?
I'm not a specialist programming linux but I can solve my thread using most code from this page of linux cnc specially the part of
"gfiber" and adding lathe = 1 on user interface of ini file
forum.linuxcnc.org/forum/search?query=st...pindle&childforums=1
wish to sync spindle with other axis on future I think could be with 5 axis mill conf adding lathe = 1
Is it possible?
How can I do it?
Last edit: 30 Aug 2020 02:27 by alejandrolleida.
- Thank you received: 7449
07 Mar 2020 01:52 #159366
Replied by tommylight on topic lathe with 3 stepper one for each axis
You will have to give us more info or pictures of what you are trying to do, that translation is not ok.
Why 3 steppers on a lathe ?
Linuxcnc is not Linux with GRBL!
For a simple stepper config you can use stepconf wizard from the menu, be it from a Live boot from USB or after installing it to HDD/SSD. Bare in mind that Live boot will not save the config so you will have to save it to another USB or HDD.
You can download the latest unofficial ISO from here and play with it in SIM mode, or install and run the machine after creating a configuration for it.
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=130#159240
- alejandrolleida
07 Mar 2020 03:41 - 07 Mar 2020 03:52 #159367
by alejandrolleida
Replied by alejandrolleida on topic lathe with 3 stepper one for each axis
Last edit: 07 Mar 2020 03:52 by alejandrolleida.
- Thank you received: 4646
08 Mar 2020 23:52 #159531
Replied by andypugh on topic lathe with 3 stepper one for each axis
I don't think that LinuxCNC knows how to configure a stepper spindle (I could be wrong).
So as a first step use the stepconf wizard to configure for a normal 2-axis lathe, and get the X and Z axis moving.
Once that is working you can start to manually edit the HAL file to add the spindle stepper.
The first stage will be to change
I have guessed most of these pin names, the real pin names are documented here:
linuxcnc.org/docs/2.7/html/man/man9/stepgen.9.html
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
You will need to make the step and dir connections too. Copy the format of the axis pins, but with the index numbers and pin numbers change.
loadrt stepgen control_type=p,p[code] to [code]loadrt stepgen control_type=p,p,v[code]
You will then have a set of stepgen, two with a ...position-cmd input pin and one with a ...velocity-cmd input pin.
You need to connect that to the spindle speed comand. Something like:
[code]net spindle-speed motion.spindle-speed-out => stepgen.2.velocity-cmdI have guessed most of these pin names, the real pin names are documented here:
The following user(s) said Thank You: alejandrolleida
- Mike_Eitel
- Thank you received: 183
26 Mar 2020 19:00 #161605
by Mike_Eitel
Replied by Mike_Eitel on topic lathe with 3 stepper one for each axis
Sorry for late stepping in, was not online a while.
I've seen that question multiple times and was always wondering why not using Hal component siggen in square mode. With 1ms servothread i would expect soemething like 500 or 250 times multiplied with 60 as 15`000 or 30`000 pulses per minute.
- Thank you received: 4121
26 Mar 2020 20:45 #161615
That has to work. I've had no problems running steppers with a square wave generated on an Arduino.
Replied by rodw on topic lathe with 3 stepper one for each axis
- alejandrolleida
25 May 2020 23:53 - 26 May 2020 00:00 #168918
by alejandrolleida
I've been working a lot finally I can move the 3 steppers with xyza configuration but "y" is useless but I can't copy the configuration of "a" axis to hal in lathe x,z configuration and returns error codes:
[axis_1]scale' not found
5425
Stopping
5425
Stopping
Last edit: 26 May 2020 00:00 by alejandrolleida.
- alejandrolleida
25 May 2020 23:58 #168920
by alejandrolleida
- Mike_Eitel
26 May 2020 06:51 #168941
by Mike_Eitel
Is this a request for help?
Than we need your lcnc version and your configuration.
- alejandrolleida
26 May 2020 11:23 #168968
by alejandrolleida
Maybe a request
Uname -v
1 SMP PREEMPT RT Debían 4.9.210-1 (2020-01-20)
About axis
LinuxCNC/axis versión 2.7.15
Uname -v
About axis
Time to create page: 0.161 seconds
