Custom Mint-19.2 with Linuxcnc
03 Mar 2020 01:33 #159055 by phillc54
Replied by phillc54 on topic Custom Mint-19.2 with Linuxcnc
No worries.
I am just building LinuxCNC at the moment after running your build deps script, looking good.
gparted would be nice.
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
03 Mar 2020 02:01 #159056 by BeagleBrainz
Replied by BeagleBrainz on topic Custom Mint-19.2 with Linuxcnc
gparted is removed as part of the Mint install process along with the ubiquity stuff and some bits and pieces.
linuxcnc 2.8 builds ok
linuxcnc 2.9 has issues /src/emc/rs274ngc/interp_g7x.cc ( I don't know if this issue has been sorted yet)
This may be fixed by installing gcc-8 and checking the instructions to make gcc-8 the default. As gcc-8 is the default in buster.
askubuntu.com/questions/1028601/install-...only-on-ubuntu-18-04
I started a clean build of kernel packages using the gcc-8 compiler. I needed to do more messing around with the control file fro gcc-7, which I couldn't be bothered with ATM. Tho I may have to do some modding.
But maybe it maybe worth waiting to till the next release of Mint.
03 Mar 2020 02:24 #159059 by phillc54
Fair enough, It is just me being lazy...
It looks like it has, it just built perfectly. I did a complete build with all documentation.
Yep, probably better off waiting.
The thing I find odd is that Mint 19.2 is supposedly based on buster/sid and they don't even list any rt linux images in the 42 thousand imges they do list.
  • BeagleBrainz
  • Visitor
  • Visitor
05 Mar 2020 01:47 #159234 by BeagleBrainz
New Kernel Packages
Version 20200305 includes all these updated packages
Kernel 4.19.106-rt44-lcnc-1 to update installs from 20200301 & earlier.
linux-imagedrive.google.com/open?id=1MTigCV53dDRaw67dVQ47R7wGieU1WXkH
linux-headersdrive.google.com/open?id=1PEk3M6Lr-iHqWOmyixmefdUSCe6kqN1Z
linux-libc-devdrive.google.com/open?id=1jxCxAxkv-yoEOK-M4qNeUk642szgDX84
  • BeagleBrainz
  • Visitor
  • Visitor
05 Mar 2020 01:48 - 05 Mar 2020 05:17 #159235 by BeagleBrainz
New Linuxcnc-uspace Packages
Linuxcnc-uspace_2.8.0~pre1.5482.g7302cc1ba_amd64 to update installs for 20200301 & earlier
linuxcnc-uspacedrive.google.com/open?id=13BgAMU8mfQunrJqE466h4A67kMmOXWII
linuxcnc-uspace-devdrive.google.com/open?id=1ULs12SgBVZY0fEX2gPqODP1od6OW7yFP
linuxcnc-doc-endrive.google.com/open?id=1dB_vjXEIndOHPWfWx6almoFSpEHnC1bn
linuxcnc-doc-esdrive.google.com/open?id=1mp7y-ozlrmTz2KCxy66y5sWnjDZFHuKY
linuxcnc-doc-frdrive.google.com/open?id=15AKgjbdMi6rROCIl5BKDFuwv_D3jaqx6
Last edit: 05 Mar 2020 05:17 by BeagleBrainz.
  • BeagleBrainz
  • Visitor
  • Visitor
05 Mar 2020 04:18 - 02 Apr 2020 23:14 #159240 by BeagleBrainz
Welcome to a respin of Linux Mint 19.2 MATE
  • New 5rd March 2020 21:48
  • Kernel Upgraded to Linux 4.19.106-rt44
  • /etc/linuxmint/respin-version.txt contains info regarding release eg kernel version, linuxcnc version to easily help ID the ISO
  • Gparted is not removed during install
  • HTML Documentation sorted
Please use win32diskimager if using a windows machine to write image to disk.
In Linux dd is recommended.
To apply updates to fresh install open a terminal and use the following, this should not upgrade the kernel.
sudo apt-get update
sudo apt-get dist-upgrade
Iso Image:
No longer available do not ask for access
MD5Sum:
Many thanks to all who have downloaded, test, reported bugs and helped.
All issues and support should be directed to this thread.
forum.linuxcnc.org/9-installing-linuxcnc...t-19-2-with-linuxcnc
Last edit: 02 Apr 2020 23:14 by BeagleBrainz. Reason: No longer available do not ask for access
05 Mar 2020 21:15 #159284 by andypugh
Replied by andypugh on topic Custom Mint-19.2 with Linuxcnc
Having no joy with RTAI kernel, graphics are really sluggish on my T530, glxgears barley runs.
Maybe some hints here?
sourceforge.net/p/emc/mailman/emc-develo...hoo.com/#msg36879222
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
05 Mar 2020 22:01 - 05 Mar 2020 22:09 #159289 by BeagleBrainz
I sorted it out, having grub boot menu be a text menu only.
It was confusing as it only came up as an issue after being installed on the T530, didn't manifest it self when installed on my Lenovo M90P desktop, running the live cd on the T530 and running as a virtual machine on the T530 did not produce this problem.
Apart from the screen resolution only being 1024x768 the Desktop is smooth and without the feeling of moving through molasses .
Fix is here, simple but took a while to diagnose.
forum.linuxcnc.org/9-installing-linuxcnc...xcnc?start=10#157661
On another Andy you maybe able to help with this one.
I've been working with a commit that sorted an issue with pncconf and another issue that escapes me, thanks to Chris for his quick replies.
Anyways I made some modifications to the debian package build so that the html docs are produced as a separate package. How does one go about merging those changes with 2.8 locally ?
I haven't made any changes to turn this on or off when doing a
debian/configure uspace noauto
Many Thanks
Rob
Last edit: 05 Mar 2020 22:09 by BeagleBrainz.
  • BeagleBrainz
  • Visitor
  • Visitor
06 Mar 2020 01:59 - 06 Mar 2020 03:12 #159296 by BeagleBrainz
Last edit: 06 Mar 2020 03:12 by BeagleBrainz.
  • BeagleBrainz
  • Visitor
  • Visitor
06 Mar 2020 08:38 - 02 Apr 2020 23:13 #159301 by BeagleBrainz
  • New 6th March 2020 14:04
  • Linuxcnc version linuxcnc_2.8.0~pre1~rmurphy.htmldocs~1c3c94442
  • 2.8 merged into local sources 6th March 2020
  • HTML docs are now a separate package
sudo apt-get update
Iso Image:
MD5Sum:
Last edit: 02 Apr 2020 23:13 by BeagleBrainz. Reason: No longer available do not ask for access
Time to create page: 0.879 seconds
